thomasrjm opened this issue on Jul 13, 2002 ยท 12 posts
thomasrjm posted Sat, 13 July 2002 at 7:44 AM
Coleman posted Sat, 13 July 2002 at 7:58 AM
I'm new to this too, but I got a free "D Sculpor 1.0" full program on Cd in the June edition of the "Computer Arts" magazine from the U.K. It's supposed to enable modelmaking from pictures. Sounds like what you're looking for but I haven't tried it out yet.
dan whiteside posted Sat, 13 July 2002 at 8:50 AM
Can you export vector curves, especially in the Illustrator format? A lot if 3D apps (like mine, FormZ) can import these curves which then can be extruded to form 3D objects. I'm not sure which of the lower priced apps can do this. D Scuplter is also avaliable in the July issue of 3D model world and might do the trick- I'd never thought about using it with a 2D images (as opposed to photographs). Best- Dan
MadYuri posted Sat, 13 July 2002 at 9:06 AM
Most 3D modelling apps can import vector graphics and create 3D models from them.
If you are adept in vector graphics you might like a NURBS modeller, NURBS are the 3D equivalent to 2D vector graphics. Try the demo of Rhino 3D, you can save 25 times with it. Also you can head over to the Rhino forum, they have some very good tutorials there.
There are some other good free or cheap 3D modelling programs out there, I'm sure someone else will provide some links. :)
thomasrjm posted Sat, 13 July 2002 at 9:20 AM
Ramnimus, I have the Dsculptor from Computer Arts but reading the magazine it needs a set number of radial views from different angles to operate, also have Photomodeller lite which is a free download and shows more promise just running the tutorial now. Dan, I've checked Corels exports and yes it can output EPS which is the Adobe Illustrator standard format, hope you can tell me some more regarding FormZ. Tommy.
thomasrjm posted Sat, 13 July 2002 at 9:25 AM
Thanks Yuri, cant seem to find it right now but sure there is a magazine disc with Rhino here somewhere but I think the free reg period has expired or save disabled maybe. Tommy.
MadYuri posted Sat, 13 July 2002 at 9:45 AM
There is the free Amapi 4.15. I found the interface quite confusing, but it has some good modelling features.
Some other modellers are Wings 3D, Anim8or and MilkShape 3D.
wdupre posted Sat, 13 July 2002 at 11:30 AM
scroll work like that is easily done with Bryce terrains just use the flat jpgs as bump maps. then they can be assembled and exported as an .obj file.
wdupre posted Sat, 13 July 2002 at 1:12 PM
My bryce suggestion was just based on the images they showed and their prefrence for using corel 2d program for design:) most of those 3d programs are hard to learn and cost a fortune and not nessasary if one just wants to assemble several fairly flat items. those pieces could be done in bryce in about 10 minutes they'd take a lot longer in many 3d modeling programs. where the 3d modelers realy shine is organic curved shapes. and you can't get much easyer then bryce which was a stipulation of their request. and it's cheeper then the full versions of all the rest, as well as being a great rendering engine for poser images:)
thomasrjm posted Sat, 13 July 2002 at 3:36 PM
Bryce is sounding good, but I remember trying it once and found the interface puzzling compared to Poser. 3Dstudio max 3 can be picked up cheap today or the Amapi free version also seems enticing too. Still trying to decide. Tommy.
EricofSD posted Sat, 13 July 2002 at 7:38 PM
Attached Link: http://www.annsartgallery.com/freeprop.html
At my tut above are some links to varous freeware and shareware modelers. Most are for non commercial use, but the registrations for commercial use are generally cheap. I'd recommend you try some of the modelers and pick one you like. Then after you get used to using modelers, you can go for the more professional packages.dan whiteside posted Tue, 16 July 2002 at 1:33 PM
