blau opened this issue on Feb 28, 2000 ยท 6 posts
blau posted Mon, 28 February 2000 at 11:11 AM
DisneyFan posted Mon, 28 February 2000 at 11:13 AM
It's the ambient color that should be black. The reflective color can be any color. :)
currently using Poser Pro 2014, Win 10
Ghostofmacbeth posted Mon, 28 February 2000 at 11:23 AM
Make sure the transmap you are using is full black ... If it isnt it will not work .. a lot of times if it is almost black it will loook black to the eye .. That could be the problem
bloodsong posted Mon, 28 February 2000 at 11:29 AM
heya; and remember to set the edge falloff transparency thing to.... whatever makes the edges fully transparent, instead of less transparent than head-on things.
viper posted Mon, 28 February 2000 at 1:14 PM
check the highlight color also it needs to be black
CharlieBrown posted Mon, 28 February 2000 at 3:10 PM
The lower the falloff, the more "transparent" the object is (I found out the hard way...:-)). And the Reflection value DOES matter if there is a map in the reflection channel; I had an image with everything else set "right" but with "ghost images" where the reflections would have been!
