Subject: Why don't these morphs work?
Phantast opened this issue on Jul 14, 2002 ยท 5 posts
Phantast posted Sun, 14 July 2002 at 8:44 AM
I downloaded some characters by ken1 that were recently placed in freestuff here - they are based on Eve 3 (which I have). The characters load all right, but all the body morphs fail to function. The dials appear, but setting any value has no effect. Has anyone had better luck? Is it a difference between Eve 3 v1 and v2?
bloodsong posted Sun, 14 July 2002 at 3:51 PM
heyas; are you turning dials on the body, or the dials on the body parts? if you're turning master dials on the body, it could be that the individual component morphs are not pointing to the correct figure/dial, or that they lost their slaving code entirely. if they don't do anything on the individual body parts.... this happens when a morph is left in a cr2 and a new (incompatible) obj is put in it. so yes, it could be a difference between v1 and v2 of eve3.
Phantast posted Sun, 14 July 2002 at 5:02 PM
They don't do anything on the individual body parts. In which case - Did anyone else get these characters to work, and if so, did you use Eve 3 v1 or v2? The obj reference in the cr2 is Runtime:Geometries:P4NudeWoman:P4NWEveV3.obj, which matches the file I have.
Phantast posted Mon, 15 July 2002 at 3:09 AM
I found the answer eventually. The Eve3 .rsr file was corrupt. Took me a while, though. Everything is now fine.
bloodsong posted Mon, 15 July 2002 at 12:47 PM
heyas; well, heck! usually if the rsr is screwt, the figure just won't load. that's a new one. glad you got it working :)
