superjunk opened this issue on Jul 14, 2002 ยท 12 posts
superjunk posted Sun, 14 July 2002 at 10:50 AM
wat do i need 2 do 2 make 3D text in bryce? plz help....thanks
tjohn posted Sun, 14 July 2002 at 11:25 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=775421
Here is a link to a recent thread on the subject here at Bryce Forum.This is not my "second childhood". I'm not finished with the first one yet.
kwmedia posted Sun, 14 July 2002 at 12:48 PM
black bkgrd, white lettering, saved as bmp... import into lattice feature, place the bmp in both areas and check ok, then from there, you do you manipulating, texturizing, etc.
EricofSD posted Sun, 14 July 2002 at 4:30 PM
I've used both the lattice and elefont, as in that thread above. Elefont gives crisp fonts that can be manipulated. The edges of the letters are rougher in lattice work.
EricofSD posted Sun, 14 July 2002 at 4:31 PM
airflamesred posted Mon, 15 July 2002 at 12:18 AM
change the record eric - i find it much neater to use a terrain @ 512 then clip top and bottom
FWTempest posted Mon, 15 July 2002 at 4:14 AM
can elefont create text effects, too? don't know much about it. For instance, I always used the lattice method, because if I needed to I could use Painter (and/or other programs) to create text on a curved baseline, rather than simply straight across. And the only time I've had a problem with rough edges is if I use some cute-sy font with lots of curly-ques. not trying to put down a program I know little about, just curious what it can do.
Phantast posted Tue, 16 July 2002 at 5:00 AM
The easiest way is to use a 3d modeller. Anim8or is free, and fine for tasks like this. Type in your text, save as .obj, import to Bryce and off you go.
Moonstone posted Tue, 16 July 2002 at 9:04 AM
where can we find the Anim8or? So we can experiment with the texts.
Aldaron posted Tue, 16 July 2002 at 10:02 AM
Attached Link: http://www.anim8or.com/
Anim8tor is also an animation program, it's renderer is still in it's infancy. And of course it's free.igohigh posted Tue, 16 July 2002 at 12:19 PM
Attached Link: http://www.armanisoft.ch/webdesign/Elefont.htm
make your own 3D Text with any font on your system for Free! EleFont: http://www.armanisoft.ch/webdesign/Elefont.htm (only makes DFX) P.S. They have a Spiralizer too;p
