Leyla opened this issue on Jul 17, 2002 ยท 4 posts
Leyla posted Wed, 17 July 2002 at 8:56 AM
hi guys, somehow i detstroyed the uv maps of victorias bikini top and bottom :( i dont know how this could happen (though i downloaded and installed a lot) i replaced the obj files with the originals but this didnt help. (in poser it only shows with the mesh collor and in 3dmax it says that it has NO UVMAP!!!?!?) i dont want to reinstall poser and all stuff because my "runtime" folder has more than 1.5 gig and that would be sooo much work. does anyone have an idea how i can fix this? can i get (and reapply) the uv map somewhere (from daz or anyone here)? thanks for trying to help leyla
c1rcle posted Wed, 17 July 2002 at 10:05 AM
replace the originals again but get rid of the rsr file that's in the folder with them, poser still thinks it's using the damaged ones. Rob
Leyla posted Wed, 17 July 2002 at 10:10 AM
hehehe, i just installed the update (i didnt do before and i never used textures on the top and bottom) the skirt seemed to has no map too thanks anyway circle! ;) leyla
reddog posted Wed, 17 July 2002 at 10:08 PM
remember if you start having troubble .rsr file is the one to get rid of. poser looks for it to use but it also makes a new one. if .rsr file is larger than .crc file then the rsr most likely is bad. i often go to the objects folders and erase all .rsr there. also keep a good copy of the main poser.rsr , .crc , .exe files in a safety folder to coppy back to the main Poser folder if anything goes wrong so you won't have to reload poser
