Forum: Bryce
Subject: Ranged falloff ?
nandus opened this issue on Feb 29, 2000 ยท 5 posts
nandus posted Tue, 29 February 2000 at 4:06 PM
I never used it. Were are the controls to set the range falloff for the lights?
Spike posted Tue, 29 February 2000 at 4:37 PM
Select the light you want to do this with and adjust it from within the "E" if I remember right. Spike
You can't call it work if you love it... Zen Tambour
Hawkfyr posted Tue, 29 February 2000 at 6:53 PM
thats correct Spike then under the preview window(in the light editor) clcky the inverted triangle to bring up the dropdown menu,select ranged falloff then tweak the falloff by dragging in the intensity windows(or whatever they're called) try it with volume visible light and infinite light. just remember the increased render time good luck Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
nandus posted Wed, 01 March 2000 at 6:14 AM
Thanks, I'll try draging up and down at the intensity window.
Phalen posted Mon, 06 March 2000 at 6:25 PM
You can also adjust the distance of the falloff on a ranged light with alt/click-hold in the light preview window. While "holding" slide your mouse around and it will change from the default range of 10.
