DEL opened this issue on Feb 29, 2000 ยท 10 posts
DEL posted Tue, 29 February 2000 at 8:57 PM
ghostboat posted Tue, 29 February 2000 at 9:28 PM
looks great! a good texture would do some good tho
lmacken posted Tue, 29 February 2000 at 9:32 PM
My thought would be to move the pivot point back so the visor sort of sweeps back over the head so it's more balanced. The present revision would be like a welder's helmet and would need little gas-pressurized struts to stay open.
Jon posted Tue, 29 February 2000 at 10:02 PM
Good work!!!That is a prop we all longed for.Hmmm...think about making few small "breathing holes" in the cheeks of the mask...:)
LoboUK posted Wed, 01 March 2000 at 4:55 AM
Excellent job DEL, although I agree the face-plate needs some airholes Paul
pdblake posted Wed, 01 March 2000 at 8:19 AM
That looks brilliant. Imacken: I used to be a welder, never had a gas powered mask though, electronic lenses yes, gas powered no.
studio187 posted Wed, 01 March 2000 at 10:31 PM
Yeah, I would like a tutorial on that as well.
DEL posted Thu, 02 March 2000 at 5:22 PM
Sorry getting back to you guys took so long, Was busy yesterday. I would love to do a tutorial! As long as you understand that most of the work (modeling) was actually done in another program. The creation of an articulated prop is done in poser in the sense that the modeled pieces are brought in and put together, then added to the library. But, If that is indeed what you guys were talking about. I'll do it. :)
studio187 posted Thu, 02 March 2000 at 8:47 PM
I can do that already. I was hopeing you could fill me in on how to attach an OBJ to it for texturing purposes. Additionaly, when you add it to the library will you be adding it as a character? I don't think you can make a prop with two pieces from the Poser interface.
DEL posted Sun, 05 March 2000 at 7:13 PM
Yes it would be a figure or "articulated prop" Using the grouping tool you can set the texture for two seperate Objs in poser, then export them as a single object. Re-import them and they retain the texture group names. Or Group and texture name them them parent one to the other and create an articulated prop and both pieces will retain the texture names.
