Subject: How to turn off the lines behind the models?
StarGate opened this issue on Jul 19, 2002 ยท 8 posts
StarGate posted Fri, 19 July 2002 at 11:54 AM
How to turn off the lines behind the lt wire models as seen in this image - they are the green lines. TIA
c1rcle posted Fri, 19 July 2002 at 12:02 PM
did you have the models selected when you did this? great looking picture by the way. the lines I think are the orientation lines, not sure if that's the right name, but you only see them while the model is selected. Rob
Valandar posted Fri, 19 July 2002 at 12:17 PM
I beleive "Show Origin" was checked for these parts. Select them, and uncheck "Show origin"
Remember, kids! Napalm is Nature's Toothpaste!
Patricia posted Fri, 19 July 2002 at 12:24 PM
Beautiful image! Except for her foot being stuck in that sphere....G
StarGate posted Fri, 19 July 2002 at 1:45 PM
OK I can not find 1 how to unslect the objects 2 can not find show origin (so I can un-select it
Patricia - is the foot better :-)
Allen9 posted Fri, 19 July 2002 at 1:49 PM
Select ONE object. Then go up to the menu at the top and select OBJECT, then PROPERTIES. In the properties screen there is an entry for "Show Origin" - remove the checkmark in that box and click OK, and the green lines for that object will disappear. Repeat as needed for other objects.
StarGate posted Fri, 19 July 2002 at 2:09 PM
Thanks Allen9 two more questions 1 I got the the props to un-show the origin - but how do I select the full body so I can un-check show origin 2 when I imported the image at normal size it is big can I re-size the document window (the window that displays the image and the models) without distoring the image ratio?
StarGate posted Fri, 19 July 2002 at 2:59 PM
OK I figured out how to unselect the full figure
