LindaB opened this issue on Jul 20, 2002 ยท 6 posts
LindaB posted Sat, 20 July 2002 at 11:57 AM
Hi, I recently moved to a new computer. I saved all of my Poser files, installed Poser to the new computer, then copied everything from the old Runtime directory to the new Poser Runtime directory. Then I opened Poser and none of my old stuff was there. Anyone have any idea what I did wrong? Would it be best to just reinstall all the DAZ stuff individually? Also what about my own libraries of Poses? What's the best way? I still have all my old files. Thanks, LindaB
thgeisel posted Sat, 20 July 2002 at 12:26 PM
I had never any porblems with moving all my poserstuff from one harddrive to another. Didnt even install poser new , only copying the whole folders with all subfolders. Maybe you copied it somewhere deeper in the subfolders? Poser needes his own filestructure,otherwise nothing is working
The 4th Party posted Sat, 20 July 2002 at 12:46 PM
if you have a metecreations and a curious labs folder in your program files, you might make sure the old runtime stuff was moved to the proper one
sirkrite posted Sat, 20 July 2002 at 5:47 PM
Linda; Look in your Runtime folder and see if there is another Runtime folder in side of it. If there is, take it and copy it to the Poser folder. If you copy a Runtime folder to another Runtime folder, it will put it inside the old folder instead of writing over it. If you copy it to the Poser folder, it will over write the old Runtime with the new one. Hope that helps. :)
LindaB posted Sat, 20 July 2002 at 5:56 PM
I finally figured out what went wrong. When I copied my old Poser files to my external drive, somehow the content of the libraries never were copied over - when I opened the folders they were empty. Fortunately, I still had the files in my old computer, so I was able to copy everything again and this time it worked. Thanks everyone for your help and suggestions. I really appreciate it :-)
PabloS posted Sat, 20 July 2002 at 10:38 PM
Whew! I bet that made your heart skip a few beats! :-)
