sonuqueso opened this issue on Jul 20, 2002 ยท 7 posts
sonuqueso posted Sat, 20 July 2002 at 5:47 PM
Is there any way to make a pre existing prop into a smart prop?
maclean posted Sat, 20 July 2002 at 5:53 PM
Select the prop, open properties (ctrl+i) and in the dialog box, click on 'set parent' When the hierarchy window opens, select the figure you want to parent it to, click OK, then save the prop to the library. Poser will ask if you want to make it a smart-prop. Click yes. The only stupid questions are the ones you don't ask. mac
ronknights posted Sat, 20 July 2002 at 6:08 PM
Oh I don't know. I still manage to ask some stupid questions. And everyone agrees with me.
sonuqueso posted Sat, 20 July 2002 at 6:12 PM
lol. Well, I'm still fairly new to poser, and that questions been bugging me for a while. Thanx for the answer guys!
lesbentley posted Sun, 21 July 2002 at 8:28 PM
P.S. Don't use "Select Subset" when you save, I did and it took me months to work out what I was doing wrong!
amokery posted Mon, 22 July 2002 at 11:53 AM
Actually Sonuqueso, I've recently started creating props and had the same question. Thanks for posting, and thanks to maclean for the help.
maclean posted Mon, 22 July 2002 at 3:49 PM
As Les said, don't use 'Select Subset' when saving.....BUT ... if you ever want to save TWO props together in the library, then 'Select Subset' is just what you need. Say you have a necklace and a cross for it, both seperate props, you can save them as one by using 'Select Subset'. When the dialog box opens, go down the list and select both items. They will be saved as one. Just remember that you'd have to use it any time you ever resave them. mac
