Forum: Community Center
Subject: How do I embed an image in a reply?
Crescent opened this issue on Mar 01, 2000 ยท 7 posts
Crescent posted Wed, 01 March 2000 at 10:41 PM
I give up! How do I put an image in a reply to a forum message? There's nothing in the Help area. A Search did not turn up any matches. Thanks!
JeffH posted Wed, 01 March 2000 at 11:07 PM
Simple HTML image tag pointed to your URL and image. < img src="http://www.your.com/your.jpg" > -JH.
fur posted Thu, 02 March 2000 at 9:25 AM
good point. i added it to the bottom of the help.
JeffH posted Fri, 03 March 2000 at 2:32 PM
Crescent, I had to delete your two replies to this thread because of the HTML you embeded prevented me from seeing the thread ;-) You said: ---------- It isn't working for me. As far as I can tell I did it right. (I do HTML a lot.) ------------------------ Then you put your link in, but you forgot one quotation mark.. yellow-techno-sm.jpg I fixed the code so I hope this shows up. -JH.
JeffH posted Fri, 03 March 2000 at 2:35 PM
It would have helped if you specified the correct JPG as well ;-) The little errors count. techno-yellow-sm.jpg -JH.
Crescent posted Fri, 03 March 2000 at 5:37 PM
Crescent posted Fri, 03 March 2000 at 5:40 PM
It worked! I was just trying to use a small file and apparently can't type any more. (Time to dig out the Mavis Bacon disks!) I tried about 10 times before this worked. Thanks so much! Sorry for the inconvenience!
