arcady opened this issue on Mar 02, 2000 ยท 2 posts
arcady posted Thu, 02 March 2000 at 1:26 AM
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
ewinemiller posted Thu, 02 March 2000 at 7:04 AM
arcady, Typically when I am trying to make a model symmetrical I: 1. delete one side 2. select the other side and duplicate with symmetry 3. line them up 4. weld But, Poser expects the facets to be in a particular order so this won't work when creating a morph target. Morph targets will probably be a manual process, though you can check your symmetry by selecting points and seeing if they are the same on both sides. Keep in mind also that most natural things are not perfectly symmetrical and a little variation helps the believability of your model. Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
