cowboy opened this issue on Jul 22, 2002 ยท 4 posts
cowboy posted Mon, 22 July 2002 at 7:38 PM
I just upgraded to poser 4.03 from poser 3
I get the following errors
" error in plugin FF3dmf.arp "
" error in plugin FF3ds.arp "
" error in plugin FFdxf.arp "
" error in plugin FFOBJ.ARP "
" error in plugin FFText.arp "
After i hit ok , Poser works fine
can someone tell me how to clear this or what to do?
brian71us posted Mon, 22 July 2002 at 7:46 PM
Did you install Poser 4.03 over Poser 3 (ie in the same directory)? It is possible that in such a case it did not overwrite/replace/erase all necessary files. Brian
hogwarden posted Tue, 23 July 2002 at 9:13 AM
Right... Poser may work, but these plugins are for mesh import/export. You could run into trouble importing/exporting meshes... Must be an install problem. Strange, but I bought an upgrade from 3 to 4.03 and was delivered a full Poser 4.03 which installs itself without reference to the old Poser 3. You probably have the same. I'd recommend re-installing Poser 4.03 fresh, not in the Poser 3 folder, as Poser4 should be stand-alone. H:)
hogwarden posted Tue, 23 July 2002 at 9:18 AM
