Forum: Photoshop
Subject: allright photoshop experts, need help here...
victimorcrime opened this issue on Mar 02, 2000 ยท 3 posts
victimorcrime posted Thu, 02 March 2000 at 11:47 AM
I need to change several P4 renders to a 256 color bmp for a project. Not a problem right?? Well, here's the problem, I need them all to use the same color palette. If one is off it won't work. I have looked through the manual, other photoshop books I have bought and looked for tutorials. Nothing quite covers this particular topic. If it really makes a difference I have PS5.
harold_u posted Thu, 02 March 2000 at 4:13 PM
U can put them all in one big piece of canvas as separate layers and arrange them so that u can see them all. Sort of like a big frame with all your rendered pictures. Then flatten the image into one. Then conver it to what u want with the 256 color pallette, once u do that, just cut each render out and save it. You might also want try to go to: Image-adjust-index color and play around with the pallette and repeat the rest. ~HaRoLd~
Traveler posted Thu, 02 March 2000 at 5:25 PM
Image-->Mode-->Color Table (can only be done on indexed color images) Save the pallette for the first one or load a 256 color pallete and the just load the same pallette for all the others. Harold's will work too, probably better actually. -Trav
