Subject: How to make Morphs on a whole figure?
cocco opened this issue on Jul 24, 2002 ยท 5 posts
cocco posted Wed, 24 July 2002 at 1:41 PM
I am trying to make a morph for a dress,and this morph includes more body parts.I want to make it in Rhino.The problem is that I can't work on each body part,I need to work on the whole figure to make the morph,so I need to merge the body parts into one. I've tried to make it in Compose,but it doesn't work,it doesn't create the figure Body,maybe because the file is too large(?)... Any help would be very appreciated,thanx.
Robert Kopp posted Wed, 24 July 2002 at 2:00 PM
I never tried this, but perhaps ... Load the original mesh into UVMapper, export a UVS. then load the changed mesh and apply the uvs. Next copy your cr2 and change the path of the obj to your new obj. Open Poser load the new cr2 and export each bodypart as morphtarget. Next would be the opening of the normal cr2, applying the new morphs, set them to the value of 1 and last make your fullbodymorph. Oh and please tell me, if this work :-) Robert
cocco posted Wed, 24 July 2002 at 4:09 PM
Hi Robert,thanx for your answer,but I think I haven't understand what you say...I need to merge the body parts into one and then back...
EricofSD posted Wed, 24 July 2002 at 11:09 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=787987
Its time consuming, but you might want to play with this technique.
Crescent posted Wed, 24 July 2002 at 11:38 PM
Attached Link: http://www.morphworld30.com/tutor.html
Traveler has the tutorial you're looking for: Full body morphing with Rhino.
