ronknights opened this issue on Jul 25, 2002 ยท 8 posts
ronknights posted Thu, 25 July 2002 at 9:20 AM
I got these textures awhile ago, and am finally trying to use them. I was surprised to see the P4 texture is missing the stephheadb.bum file. I've never run into this problem with DAZ stuff before. I'm letting you know in case you get this texture. I have sent an email to DAZ tech support about the problem. I won't get a reply till tonight probably since I am heading to work soon.
Kelderek posted Thu, 25 July 2002 at 10:46 AM
That is strange... I have that texture too, and it installed the stephheadb.bum correctly on my machine. It also loads it correctly when applying the included MAT-files.
kjlintner posted Thu, 25 July 2002 at 11:35 AM
The hires exture did have a problem when they were first released, but DAZ emailed everyone who wrote to them a link to download the corrected version.
Puntomaus posted Thu, 25 July 2002 at 3:36 PM
And where is the problem with that? Load a sphere prob, load the jpg and let Poser convert it to a bumfile. And if you have ProPack forget about the bum, that uses jpg's instead.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
ronknights posted Thu, 25 July 2002 at 9:33 PM
OK, let me explain. DAZ's textures traditionally don't need any sort of fiddling with BUMs and stuff. The textures are good to go right out of the box. That has always been a good hallmark of DAZ... Other people who supply textures often require you to go through that extra step. Never DAZ. There are no "...bum.jpg" files in the texture section. I've checked. If there were, this would be a step backward for DAZ. They've never handled their textures this way. When this bum file is not found, Poser locks up for a very long time. I haven't seen that happen very often since I started using Windows XP. I wasted a good hour or so fiddling with this problem. That's not a good thing. The texture I've bought is described as "medium," and "standard." I have no idea why the texture seems to have two names. I've checked my purchase history to verify the two names. As of tonight I've received no response from the DAZ tech email address. Frankly I'm surrprised at that. Maybe their customer service email address is more responsive. I'll try them now.
Puntomaus posted Fri, 26 July 2002 at 4:14 PM
Ron, there is nothing wrong, you have to convert the StephBodyB.jpg and the StephHeadB.jpg file to a bum file in order to use the P4 Matpose files. There are no bumfiles supplied with the purchase - you have to do this yourself. I just installed the Stephtextures again into a seperate folder to see what's in there because I always delete all the P4 stuff as I use ProPack. The purchase only comes with jpg files.
Every
Assange
ronknights posted Fri, 26 July 2002 at 9:09 PM
ronknights posted Sat, 27 July 2002 at 12:14 AM
I know all about saving file space by converting the jpg. My point remains: I've NEVER had to do this before, and I've been buying DAZ stuff for a year or so now.
