Forum: Bryce
Subject: Help! please....
Zhann opened this issue on Jul 29, 2002 ยท 5 posts
Zhann posted Mon, 29 July 2002 at 2:16 AM
Hi, I just installed Bryce5 and already I've run into a problem. Although the manual says there are file menu options to set initially,i.e., create a document, resolution, positioning the camera etc.,no file men shows in the app. After reading the 'readme' one of the problems they state is no file options will show in WinNT (it doesn't do something) however I have WinXP which I understand is based on NT. Does anyone know a work-around for this?
Bryce Forum Coordinator....
Zhann posted Mon, 29 July 2002 at 2:17 AM
As an aside I've contacted Corel but have yet to receive an answer for this I thought someone here might know...
EricofSD posted Mon, 29 July 2002 at 3:53 AM
Hehehehehe, if you have b5 you have to move your mouse to the top of the screen for the menu to pop up. They hid it, unlike B4 that shows all the time. Hope that helps.
Zhann posted Mon, 29 July 2002 at 4:11 AM
Thanks, I'll try it...
tuttle posted Tue, 30 July 2002 at 9:05 AM
Bryce on XP is a bit funny about its windows. Most of the time on XP you can't access the task bar with Bryce maximised, even though the task bar might be visible on-screen. You need to minimise first. Until you get used to it, this can lead to horror <:0 when you try to click on another app in the middle of a render but Bryce decides you've actually clicked on-screen and stops the render and you don't realise! Rest assured Zhann that you WILL have all the options there somewhere!
