Forum: Bryce
Subject: Need help with Lightning
Bladestorm opened this issue on Mar 05, 2000 ยท 11 posts
Bladestorm posted Sun, 05 March 2000 at 3:32 PM
Hey there people, I'm working on this 12th century gothic project, and so far I've been able to make anything I wanted with Poser Bryce and Carrara... until now. I just can't figure out a way to make any realistic lightning. Could anybody help me out with this?
bonestructure posted Sun, 05 March 2000 at 6:39 PM
if you're rendering in Bryce,and it's an interior scene, turn off the atmosphere and get a completely black stage. Then use small,dim, radiant lights wherever you want your light sources, such as torches, candles, etc. if it's outdoors, make it a very dark sky and do the same thing. Or create and object, then in Bryce group a radiant light or spotlight with it. On all those, play with luninosity and falloff till you get what you want. Using texture gels over the lights also gives interesting effects.
Bladestorm posted Sun, 05 March 2000 at 7:45 PM
Thanx alot, i'll try it this instant.
bonestructure posted Sun, 05 March 2000 at 8:28 PM
doh, sorry, I thought you said lighting. I don't sleep much, my mistake. If you have photoshop with the xenofx plug in, that's what I use anytime I want lightning. Here's one idea I haven't tried, but it should work. Take a bare tree model boolean it until you have only the branchings you want, turn it upside down, apply a texture that would make it appear to be light, then take the render into photoshop, select the lightning by using the wand, then apply eye candy's glow filter to it. Sorry about the misunderstanding.
Bladestorm posted Sun, 05 March 2000 at 10:06 PM
Now this makes more sense, I must admit I was all confused with your other answer. I have photoshop but not the plugin, is it a free plugin? if yes where can i get it
Roshigoth posted Sun, 05 March 2000 at 10:13 PM
Nope... Neither xenofx nor eye candy plugins are free.. but they're worth the money, in my opinion. Probably among the most useful plugins I've ever used.. Actually.. they're just about the only ones I use. Rosh
Ghostofmacbeth posted Sun, 05 March 2000 at 11:55 PM
There is also a material for electricity at chemical studios .. however you can do it a couple of different ways in Bryce .. here is an example all done with no post work ThunderGod.jpeg
Bladestorm posted Mon, 06 March 2000 at 4:19 AM
YES Thats IT!!! How didja do it, Exactly what I had in mind, PERFECT! I'm going ballistic here. Do you have any idea how long I've been trying to get an effect like that.
Ghostofmacbeth posted Mon, 06 March 2000 at 1:53 PM
Well there is a few different lightning strikes ... The ones in back are drawn with reference in photoshop. Quick angular clicks on a black background with white ... I supposed you could take a scan of lightning as well pushed very high contrast ... In Bryce you make a picture plane and then load the lightning in one channel and in the second you load it as a transparancy ... Put a light near the strike and there you go .. Hope that helps
Hawkfyr posted Mon, 06 March 2000 at 6:31 PM
Very cool
“The fact that no one understands you…Doesn’t make you an artist.”
Bladestorm posted Tue, 07 March 2000 at 1:31 AM
Yup sure did
