yspark77 opened this issue on Jul 31, 2002 ยท 3 posts
yspark77 posted Wed, 31 July 2002 at 10:14 PM
wdupre posted Wed, 31 July 2002 at 10:43 PM
If it is low rez vicky 1 I believe that it is acceptable to distribute the Cr2 the same as the high rez version though you should just ask Daz about that. I believe that it is only the V2 version that has a restricted Cr2
Kalypso posted Wed, 31 July 2002 at 11:34 PM Site Admin
Attached Link: http://mine.site.ne.jp/dld/
If this is Vicky 1 lo res then you can also just spawn a morph target, export it making sure only the last option(export as morph target) is checked and run it through Morph Squeeze. You'll be left with an .obj that is ok to distribute. If you've used only morphs that come with the figure or it's Vicky 2 lo res then just save as a fc2 file and distribute that, there's no need to distribute a whole cr2 just for a face morph. There have been several lo res vicky characters released: Minerva has a complete character with texture and hair at Digital Love Doll (check under freestuff, character MT) called Yumi http://mine.site.ne.jp/dld/ Taruru has Serena here http://isweb34.infoseek.co.jp/photo/tarurud/ Also at d!works you'll find Ai http://www.valley.ne.jp/~okaniwa/cg/down.htm http://www.valley.ne.jp/~okaniwa/cg/dworks.htm I'm sure there are others but that's all I can think of now. Look around, check their links, you won't be disappointed! Also keep in mind that any fc2 files that work for Vicky will also work for Vicky lo res as long as it's the same version i.e. Vicky - Vicky lo res, Vicky2 - Vicky2 lo res.
