Forum: Bryce
Subject: Export feature in bryce
LadyBea32 opened this issue on Aug 02, 2002 ยท 4 posts
LadyBea32 posted Fri, 02 August 2002 at 11:32 AM
i want to export a room i made in bryce so i can use it in poser. well when i go to file export object. its not on. how do i get it to turn on so i can export the objects i made. It doesnt help either if i import an object made in poser and then need to save it so i can return it back to poser. Can someone please help? thanks bea
airflamesred posted Fri, 02 August 2002 at 12:11 PM
Export is confined to terrains sy lattice and stones.You're only possible way around this is to altitude render your room (roof permiting) and re-import jpeg for terrain. Poser needs to be saved as poser file. you are only importing a static obj.
wozzyke posted Sat, 03 August 2002 at 2:48 AM
how can you do this ltitude render???? Have beel looking for a way around too but havnt found one so I would like to know your way to do it..... wozz
airflamesred posted Sat, 03 August 2002 at 5:14 AM
Simply choose altitude render from the options (small arrow next to render buttons)and change to overhead view. This provides a good G2h map for terrain.Just mess around with the final proportions - good luck
