arcady opened this issue on Mar 06, 2000 ยท 6 posts
arcady posted Mon, 06 March 2000 at 11:20 AM
Can I make an object glow in Poser? Such as a candle flame? I can do it in Carrara by putting a lightbulb on the object but I haven't been able to achieve that effect in a Poser render. Should I just give up on using Poser to render and take it all over to Carrara? Or can you do effects like this? I was making a scene last saturday (unfortunately saved to my PC or I'd post a render to who you all) of a person doing a ritual in a room by candlelight and nothing I tried could get the light to 'come out of' the candle flame.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
CharlieBrown posted Mon, 06 March 2000 at 11:25 AM
You can add a "true" glow in post-render with plug ins, and you can "fake" a glow by playing with Ambient Colors, Reflections, and transparancies with moderate to high fall-off values. I'd suggest experimenting.
CharlieBrown posted Mon, 06 March 2000 at 11:28 AM
Oh, I hit "Reply" too soon... And I'm assuming you're using Poser 4; if I'm wrong then you can ONLY use Ambient Colors to create a "fake" glow, and it probably won't give you the effect you want. To use Transparancies to fake a glow, you need to create a second copy of the item, about 2-4% larger than the first and positioned "around" it, and make the copy completely transparent (100% min/100% max) with a fall-off value about halfway across
ClintH posted Mon, 06 March 2000 at 11:28 AM
Yea - Take it all over to Carrara! ;) I feel it has a much more robust render engine and I also feel the renders are better than Poser renders. You also get all the fun post render effects like glow, Aura, Lens Flares etc... Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
arcady posted Mon, 06 March 2000 at 12:41 PM
ClintH: Yeah. I went through the lighting tutorials last night and found the lightbulb. I had wanted that Poser scene I was composing to have two light sources: 1. Ambient moonlight from an outside window. This not only failed to bring in any light into the room but it also left my backdrop image of a jungle completely black. 2. A glow coming out of the candle illuminating the figures and objects in the room. This completely failed, I ended up with 3 spot lights just above the candle all pointing in different directions and still not getting the proper effect. I added one general light to the room at a very low setting and of course it failed to have the 'light coming out of the candle' effect. When I found the bulb in Carrara I figured this was what I needed. But I guess it or an equivelant doesn't exist in Poser. I'm still having difficulty moving things over to Carrara. The Carrara shaders have so many more choices and I find it loses transparency when you move it over. You have to rebuild that using a somewhat different method.
Renderosity
Gallery
lmacken posted Mon, 06 March 2000 at 7:08 PM
Ref: Message #68350 from Ikyoto on 1 Feb, 2000 for a solution involving multiple spotlights (therefore P4 only).
