Shiby561 opened this issue on Aug 06, 2002 ยท 6 posts
Shiby561 posted Tue, 06 August 2002 at 2:44 AM
How do I get a brycefile into poser 3d. the only way i know how is to import it as a background image but that makes it flat and of caourse only in the background... plz help!
Little_Dragon posted Tue, 06 August 2002 at 4:19 AM
You can export the Bryce terrain as an .obj file, and then import that into Poser. I don't think that there's any easy way to transfer other Bryce objects.
bikermouse posted Tue, 06 August 2002 at 4:46 AM
or you can export the terrain map to carrara and save as an obj if you're using bryce 3.
Shiby561 posted Tue, 06 August 2002 at 4:53 AM
How do I export it as a OBJ file. -bikermouse0 im using bryce4. thx anyway. I am new to all this so plz explain how i export it as a obj file...
bikermouse posted Tue, 06 August 2002 at 5:07 AM
Shilby, I'm using bryce 3. Bryce 3 will only export as an obp. I hear it is possable to save as obj in bryce 4 but you will either have to hope someone here that has bryce 4 reads your question or repost it in the Bryce Forum. I hate to bring this up, but isn't that in the B4 manual? If you go into terrain editor you can save to the clipboard then in carrara paste from the clipboard and then save. that should save the day until you get a more helpful response. -TJ
wdupre posted Tue, 06 August 2002 at 7:48 AM
