Subject: Rendering over a transparent background
Red_Baron opened this issue on Aug 07, 2002 ยท 7 posts
Red_Baron posted Wed, 07 August 2002 at 2:17 PM
Is it possible to render with no background? What Im interested in is a completely blank background like a transparent background in photoshop. Background color is a problem when rendering objects that use trans maps, especially hair. Trying to separate them in photoshop is kinda tedious and doesnt work that well...
bantha posted Wed, 07 August 2002 at 2:27 PM
You should save the picture in psd-Format in Poser, then the alpha-Channel is preserved. You will have the transparent background in the alpha channel.
A ship in port is safe; but that is not what ships are built for.
-"Amazing Grace" Hopper
Avatar image of me done by Chidori
Barbarellany posted Wed, 07 August 2002 at 2:47 PM
But what if you want to have an animation with transparency background?
aleks posted Wed, 07 August 2002 at 3:35 PM
save a succesion of tiffs in 32 bit with alpha channel. but i think also that if you save an avi with no compression and in 32 bit witrh alpha you'll get the same result.
shadownet posted Wed, 07 August 2002 at 3:40 PM
You can also save the file as a png if exporting to PSP 7, (not sure about any of the others) set the background color for the document window to the color you want to have as the background transparency.
Red_Baron posted Sat, 10 August 2002 at 8:34 AM
I don't understand when you say; "You will have the transparent background in the alpha channel." I know how to export as a psd or tif and be able to access the alpha channel. What I'm not clear on is how exactly to separate the background in photoshop.
aleks posted Sun, 11 August 2002 at 5:42 AM
menue "selection -> load selection" and then in "channel" you choose "alpha channel". hit ok. hit delete. deselect (strg-d). now go back to layers-tab and put the background that you want on the lower layer, it'll show through. i guess :) i'm writing this from my memory...
