Forum: Photoshop
Subject: please help with my jagged line.
marzipanlil opened this issue on Aug 09, 2002 ยท 4 posts
marzipanlil posted Fri, 09 August 2002 at 9:15 AM
Please can someone tell me what I can do about the following problem? I undertook my first digital photography job yesterday which included an image of a chap working at his new invention. The piece of equipment he is using has a tall, narrow stem. The original file is 30cm by 20cm. The stem on the equipment is then about 3mm wide on the screen. When I reduce the size of the image to something suitable for a web page the stem is very jagged. This doesn't look good at all. What can I do? Is my fledgling career about to hit the buffers? I tried using the smudge tool on it but it looked a mess. Thanks in advance, all those who ride to the rescue. Should I attach a file with this kind of question? marzipanlil
retrocity posted Fri, 09 August 2002 at 9:30 AM
Please do, maybe by seeing the image we can suggest a few pointers. What is the final size/output?? :) retrocity
lundqvist posted Fri, 09 August 2002 at 9:59 AM Online Now!
Also, what resampling method are you using? PS normally does a very good job at downsampling.
SPACEY posted Sat, 10 August 2002 at 7:39 PM
Sounds like you need to inverse select those pixels and create a path. Expand it a little and then reduce the size of your image. If there are a lotta BG elements just use the path tool directly... _ _
Must've slipped my mind...but it's the thought that counts...
http//www.wholebitmedia.com
