Forum: Bryce
Subject: help please!
lj456 opened this issue on Aug 09, 2002 ยท 8 posts
lj456 posted Fri, 09 August 2002 at 10:55 AM
the elvation palette under the terrain editor won't show up and i need it for like every tutorial that i have come across. i just started using bryce so if someone try to help i would appreciate it.
tuttle posted Fri, 09 August 2002 at 12:02 PM
What happens when you click the tab? Is the tab there? Are the other tabs there and do they work?
lj456 posted Fri, 09 August 2002 at 2:30 PM
Well there is an elevation, pictures, and one more tab that i can't remember off the top of my head but when i click the two tabs BESIDES the elvation they work..but when i click the elevation tab no options pop up like the other two...
tuttle posted Fri, 09 August 2002 at 2:41 PM
That's a bit weird. The elevation tab should be the default one when you go in -- i.e. the options should just be there (like fractal, noise, erosion, etc.) What is there in place of the options? Just blank space? Very odd, unless I'm thinking of the wrong thing.
lj456 posted Fri, 09 August 2002 at 5:12 PM
nope your right where all those options you named are SUPPOSED to be there is just blank space..
madmax_br5 posted Fri, 09 August 2002 at 10:16 PM
try re-installing. Copy all of your presets and stuff and stick them in another folder. The just un and re-install bryce.
tuttle posted Sat, 10 August 2002 at 5:48 AM
Yes, try a re-install. Something has gone wrong here. Let us know if it fixes it.
lj456 posted Sat, 10 August 2002 at 10:46 AM
ok thanks for your help guys i'll try it out and let you know how it turns out tomorrow because m not at home. but thanks again i appreciate it. =)
