Subject: So Sad, we can put a man on the moon but no fire in Poser...
zorares opened this issue on Aug 09, 2002 · 11 posts
zorares posted Fri, 09 August 2002 at 4:09 PM
I just spent "forever" going through the Poser Forum's archives and found nothing on making FIRE in Poser. Please tell me I screwed up my search. Is it possible or am I stuck in Photoshop?
http://schuetzenpowder.com/sigs.jpg
thebert posted Fri, 09 August 2002 at 4:20 PM
Attached Link: http://www.renderosity.com/softgood.ez?ViewSoftgood=2761
Well, I think you need to check out the link this is one of many product that are fire. I hope this help you thebert
The difference between stupidity and genius is that genius has its limits.
wheatpenny posted Fri, 09 August 2002 at 5:13 PM Site Admin
Use a cone from the "Prop Types" library and add a flames texture. Use the same tex as a trans map and set both min and max transparency to 100%.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Little_Dragon posted Fri, 09 August 2002 at 5:15 PM
I'm working on it.
The current build (seen above) was rendered entirely in Poser 4.
I have high hopes for Poser 5. Even though it doesn't have a particle system, you'd be surprised at what you can accomplish with animated procedural textures and turbulence deformers.
Thorgrim posted Fri, 09 August 2002 at 5:45 PM
That's actually not too bad, I never thought of doing it that way.
zorares posted Fri, 09 August 2002 at 6:13 PM
Wow, Now I've got my work cut out for me. Thanks everyone. So much for sleep tonight. : )
lalverson posted Fri, 09 August 2002 at 6:21 PM
Attached Link: Camp Fire & Fire Place
Deimos makes the best currently available fire around. i use it alot because it's light on poser and takes lighting very well
Little_Dragon posted Fri, 09 August 2002 at 7:12 PM
My main beef with Poser 4 illumination is the lack of omni lights (or point lights, or whatever you care to call them; they radiate light equally in all directions). I see that Poser 5 will add "global lights" to our current light-source toolbox (infinite and spotlight). I'm hoping that this'll be my long-missed omnis, and not just some form of ambient lighting.
FyreSpiryt posted Fri, 09 August 2002 at 8:17 PM
For my avatar pic, I used the fire from the "Witch burning" set in freebies. I think it was here, although it might have been another site.
FyreSpiryt
"She's dancin' in fire
But I'm the one who's burning'...
She just laughs
Throws her hair back
And says come on, come on boy
Come on in the fire's fine." ~"Gekko", Everybody's X
davidm posted Sat, 10 August 2002 at 9:20 AM
Attached Link: http://www.renderosity.com/softgood.ez?Who=davidm
Wow! Great balls of fire! These fire effects are fabulous!! :-) Fire was the main reason I created my FX Paks - All my friends wanted to bring their Poser dragons to life! (And you can't have a dragon without fire!) Dave :-)
Phantast posted Sat, 10 August 2002 at 4:32 PM
kawecki is the master of fire in Poser and is the person you need to consult.
