JBSettle opened this issue on Aug 09, 2002 ยท 7 posts
JBSettle posted Fri, 09 August 2002 at 5:53 PM
Does anyone know a good method for rendering Cel Shaded pictures. I know Poser has the cartoon view mode, which is more or less what I'm looking for. However, since it is a view mode and not a render mode, you don't get antialiasing, and the ability to save the 2d image. Is there a way to have Poser's renderer do cel shading? The back of my mind tells me there is a way, probably something very simple, but right now I can't figure it out. Maybe I'm just having a Friday moment. Thanks Josh
Little_Dragon posted Fri, 09 August 2002 at 6:08 PM
The solution isn't very simple, but it's easily overlooked:
Switch the display mode to Cartoon or Cartoon-with-Lines, then render as a one-frame animation.
Animation menu --> Make Movie
Set the Sequence Type to Image Files
Set the Quality to Current Display Settings
Enable antialiasing
Set the Time Span to Start 0:0:0:0 and End 0:0:0:0 (1 frame)
The 4th Party posted Fri, 09 August 2002 at 9:22 PM
or you could use those settings and just antialas the document (Alt=Ctrl=R) and export the Image then ofcourse, there is always the sketch designer, you might play with that and see if you can get some results you like :)
SmallFry posted Fri, 09 August 2002 at 9:24 PM
I think you can get the same effect by choosing Render/Anti-Alias Document. Then by going to File/Save As... when it's done, you ought to be able to save the image. I hope this helps...
jjsemp posted Sat, 10 August 2002 at 12:57 AM
The REAL problem with using Poser's "cartoon render" mode for cel shading is that "cartoon render" mode won't render textures, so everything ends up being delineated in solid colors only -- and if a detail isn't built into the actual mesh of an object, then you won't see it at all in "cartoon render" mode. Therefore, Poser doesn't have a true cel renderer. When I saw the folks at Curious Lab at last year's SIGGRAPH (in L.A.) the ONLY thing I asked them for in Poser 5 was a decent cel shader. They all looked at me dazed and confused, like deer caught in the headlights. I never did understand why my simple request seemed to baffle and confuse them -- especially when you think of how many comic book artists out there use Poser and would probably LOVE to have something that would render out in 2D.
Little_Dragon posted Sat, 10 August 2002 at 1:28 AM
Two renders: one textured, one cartoon-shaded. Blended together in a paint program to achieve a shaded look with textures.
JBSettle posted Sat, 10 August 2002 at 9:54 AM
Thanks for the excellent ideas. Though for what I'm trying to do, it may take to much time to get cel shading done. Oh well, guess I will have to go for the "realistic" look in my work. Thanks Josh
