jambot opened this issue on Aug 13, 2002 ยท 6 posts
jambot posted Tue, 13 August 2002 at 10:14 AM
This is probably a stupid question, but I've been confused clickin everything on how to make the picture black and white so that it can be used as a bump map, that kind've black and white. Any help you can give would be aprecciated. Thanks James
Valandar posted Tue, 13 August 2002 at 11:21 AM
Ctrl-Shift-U Or Image - Adjust - Desaturate
Remember, kids! Napalm is Nature's Toothpaste!
retrocity posted Tue, 13 August 2002 at 11:34 AM
If i'm correct you mean the BUM files for Poser? (I don't have Poser so sometimes i need to shoot from the hip...) If they are like Displacement Maps (which are images in Photoshop that take the White pixels and shift to the high/positive position and Black pixels to the low/negative position) that will add surface and realism to an object. Basically you can "desaturate" the image and adjust the contrast/brightness. Any pixels in the Grey (50% range) wont have any effect on the image you apply it to. i may be TOTALLY-OFFBASE so take it with a grain of salt!! :) retrocity
jambot posted Tue, 13 August 2002 at 11:37 AM
Thanks to you both, I will try them out and thanks for replying and your help James
Valandar posted Tue, 13 August 2002 at 12:02 PM
In Poser greyscales are used. And it actually has to be inverted to work properly, for P4 at least.
retrocity posted Tue, 13 August 2002 at 12:09 PM
Thanks Val, SEE it told you i don't know Poser! ;) retrocity
