the_sable_baron opened this issue on Aug 13, 2002 ยท 5 posts
the_sable_baron posted Tue, 13 August 2002 at 10:35 AM
how do i get a cr2 file imported into poser? have imported jpeg's, obj's, etc. how do you get those rsr, and cr2 files in?
kumo posted Tue, 13 August 2002 at 10:40 AM
simple go to explorer and simply drag them in, this works fine for me, be sure to read the text thats comes with it, because if you drag it to the wrong folder it wont work hope this helps kumo
HaiGan posted Tue, 13 August 2002 at 10:43 AM
What Kumo said. Just copy and paste them into the appropriate folder in your PoserRuntimelibraries directory, and Poser will find them for you.
Kelderek posted Tue, 13 August 2002 at 1:59 PM
Attached Link: http://www.renderosity.com/~pzr/extensions.html
Here is a guide to where all kinds of Poser file types belong in the somewhat confusing Poser folder structure.terminusnord posted Tue, 13 August 2002 at 2:29 PM
Take that list with a grain of salt, it's not comprehensive or 100% accurate. Here are a few things I noticed right off: .MAT and .MOR for Poser??? All the MAT pose files I've seen for Poser are .pz2. Ditto for the MOR and MAP. If you name your MAT poses .mat, you may inadvertently associate it with a different program (e.g. a Bryce .mat file). Also, the small .rsr files contain the thumbnails for more than just cr2's. They are used on Windows for ALL the library thumbnails, so you will find them in every folder in the library. Large .rsr files do contain a copy of the OBJ file also, but this page does not mention that it's a binary version you can't work with in any other program (or text editor). -Adam
