Forum: Photoshop
Subject: Compensating for CMYK conversion
merbliss opened this issue on Aug 13, 2002 ยท 3 posts
merbliss posted Tue, 13 August 2002 at 8:19 PM
Hi,
Here's a crop from an image I'm halfway through. As you can see there is a marked difference in color quality after color conversion. My question is: is it possible to get the image close to the RGB version again using the color balance or hue/saturation functions....I've started playing around with that but the results look kind of nasty so far.
Thanxz. Although come to think of it as I type this, the cmyk version might look better!
AlphaOmega1 posted Wed, 14 August 2002 at 12:46 AM
Try increasing the pictures saturation, or the contrast. Try tweaking some things in the image options menu.
Slynky posted Wed, 14 August 2002 at 5:11 AM
using your colour balance, curves, hue/saturation, and brightness/contrast, you should be able to get it to look right again. t'is a tricky mofo it is. If you don't tend to use RGB only functions, such as certain filters etc, you may as well start all your files in CMYK from the start bro...
