chuckerii opened this issue on Aug 14, 2002 ยท 3 posts
chuckerii posted Wed, 14 August 2002 at 9:18 PM
Maybe it's just me, but I can't figure this one out. For example, I want to do two simple moves with a conical camera, first dropping down then moving right in an "L" shape. When I play it back, the camera doesn't form the corner of the "L", but rather dips down below the second plane of the move and then back up to finish, making it more of a curvy "L." Why is this?
mdesmarais posted Thu, 15 August 2002 at 6:53 AM
Check how your tweeners are set- I think they should default to linear, but it sounds like you have some overshoot? How many keyframes do you have, and did you make sure that you are only changing one dimension between each of them? Markd
chuckerii posted Thu, 15 August 2002 at 9:32 AM
Thanks Markd... it was a tweener problem. I had them all set to Beziers instead of Linears. Thanks again.
