SVicious opened this issue on Aug 18, 2002 ยท 4 posts
SVicious posted Sun, 18 August 2002 at 12:50 AM
Hello I just completed my first poser figure. Here is what I need help with. I want to package the figure, but when I went to the folder it was in I did not see a cr2 or rsr files of the figure instead they were file.crz and file.obz I know there is a cr2 and a rsr converted in the free area, but I would like to know what would be best for packaging it, using the above files or in the cr2 and rsr file format? if the file names are best to be converted to cr2 and rsr please tell me which one needs to be cr2 and which one rsr? thanks
Little_Dragon posted Sun, 18 August 2002 at 2:38 AM
I'm guessing that you have Pro Pack. It has an option to compress files, which you can toggle on or off from the Edit menu --> General Preferences.
Pro-Pack-compressed files have a "z" at the end of the filename extension, so that a cr2 become crz, etc. It never occured to me that it compresses the .obj file also, but that is apparently the case. Other than turning off compression and resaving the figure to the Library, I'm not sure how you could convert those files. I do recommend that you convert them, though, because regular Poser users (without Pro Pack) can't read the compressed files.
Pro Pack doesn't create .rsr thumbnails for its Library. It uses .png thumbnails instead. You can convert these to .rsr using yarp's P3dO Explorer, available in Free Stuff or at SENO Software. It has an rsr-to-png converter plugin.
lundon_Don posted Sun, 18 August 2002 at 10:13 AM
I haven't been able to get onto SENO all weekend. Anybody know if there is a problem?
Little_Dragon posted Sun, 18 August 2002 at 6:38 PM
Works fine from my corner of the 'Net. Maybe you have some sort of routing problem somewhere between your machine and SENO's server.
