LadyBea32 opened this issue on Aug 18, 2002 ยท 10 posts
LadyBea32 posted Sun, 18 August 2002 at 6:58 PM
jambot posted Sun, 18 August 2002 at 7:16 PM
go into the materials section and on then on the part of clothing you want goto to transparency which is at the bottom right then load the file then at the top centre make sure that trans min and trans max are at 100% and it should work. James
lesbentley posted Sun, 18 August 2002 at 8:20 PM
Try using your graphic as both a texture map, annd a trans map.
lesbentley posted Sun, 18 August 2002 at 8:29 PM
LadyBea32 posted Mon, 19 August 2002 at 10:49 AM
I think what i need done cant be done other than to post work it. I was talking of the fringe on the dress. the little hairs...i want that to show like hair does. K sorry, i think i well not do this texture on anything. thanks for you help though
jelisa posted Mon, 19 August 2002 at 11:38 AM
You can make a fringe type transparency, like lesbentley mentioned using a black/white trans map. One was done for the RuntimeDNA mini-dress, so it can be done. Basically, you have the white area of the fringe that you want to stay, separated by black areas to use as the transparent area. -darlisa
Poppi posted Mon, 19 August 2002 at 5:01 PM
okay...i think you want to make everything but the hairs transparent, right....just use the lasso tool, and cut out the bottom part in sections...like making a psp picture tube....then, fill those sections with black.... do it holding down your shift key, to add to the selection, each time you lasso one of them off. then, reverse selection, and paint the hairs white.
lesbentley posted Mon, 19 August 2002 at 5:21 PM
LadyBea32 posted Tue, 20 August 2002 at 12:18 AM
yes i can do those kind of textures, its getting hair to do what its supposed to. i guess would be like the hair you can find in freebies. how it has a transmap and when its rendered in poser it looks real. that is what im trying to do with that texture. but i cant seem to do it right and i dont understand how.
lesbentley posted Tue, 20 August 2002 at 3:46 AM
LadyBea32, I don't understand. Are you trying to make the dress look hairy, or to put a fringe on it, or to put a hairy fringe on it, or to get hair to show through the fringe?
