DangerKitty opened this issue on Aug 20, 2002 ยท 3 posts
DangerKitty posted Tue, 20 August 2002 at 12:30 PM
I'm having a problem with a body morph... I've gone in to edit it by hand to add the "Body" settings, but no matter what I do, the Muscular setting doesn't translate to the figure. The setting itself is still int he file, it just doesn't show up on the figure when I load the morph. Is there anything I can do to remedy this? Any help would be appreciated.
lesbentley posted Fri, 23 August 2002 at 12:45 PM
Not enough information to make a proper diagnosis, but it might be a case of the master channel name in the master not matching the master channel name in the slaves. Search the master channel name in a text editor to make sure it exists in the slaves. Also if you copied the FBM from another character, make sure the figure number is correct in the slave channels.
lesbentley posted Fri, 23 August 2002 at 7:13 PM
DangerKitty, if you post your master channel, and the 5 control lines from just one of your slave channels, we can probably tell you what the problem is.
