konan opened this issue on Aug 22, 2002 ยท 69 posts
konan posted Thu, 22 August 2002 at 11:30 AM
Attached Link: http://innuendo.ev.ca
I would like to write a small (yet essential) utility program to enhance for Poser. It could be a program to help manage you Poser library, edit a CR2 or PZ3 file, or anything like that.It should be simple in concept, yet highly useful. My motivation for writing this software is to draw attention towards my commercial software packages (honesty is the best policy), but in itself will be completely free for everyone to use.
There may be a Mac (OS X) and Windows (all) version of this utility.
Please post you suggestions for a freeware utility to enhance the Poser experience. All suggestions should be for features that are not included in the upcoming Poser 5 program (why be redundant?).
David John Fielder (Konan)
Proprietor of Innuendo Software
quixote posted Thu, 22 August 2002 at 11:52 AM
Since P5 gives one the possibility of having multiple Runtimes, how about an explorer type utility, that installs a file (character or object with all or some of its attending sub-folders)in 1 or more Runtimes with just one click. Don't know if that's in P5 or not...
Un coup de dés jamais n'abolira le
hazard
S Mallarmé
c1rcle posted Thu, 22 August 2002 at 11:52 AM
I have an idea, but it might be a bit difficult to explain & program. here goes : A program that reads the texture settings of a cr2, then examines the folder where the textures are compares them then corrects the cr2 to point to either .jpg or .bum files. Rob
c1rcle posted Thu, 22 August 2002 at 11:53 AM
mine would be mostly for poser4, realised that once I'd hit post. Rob
quixote posted Thu, 22 August 2002 at 11:58 AM
I work at a res of: 16001200 in Poser and Photoshop. I use 1024768 in other apps. I'm getting old and lazy, not to mention forgetful. I wish I had a way of programming the prefered res in Poser so that it would always open at the prefered res. without my having to change it manually. Some games do that. Hey! you asked :) Luck, Q
hazard
S Mallarmé
dragongirl posted Thu, 22 August 2002 at 12:03 PM
A MAT file creator for all kinds of human and architectural, etc., figures. :-) -dg
Orio posted Thu, 22 August 2002 at 12:12 PM
yes, something that makes creation of MAT poses easy and intuitive!
TalmidBen posted Thu, 22 August 2002 at 12:24 PM
More than mat poses, that makes CONFORMING CLOTHING EASY to create! BTW, David, you are brilliant.
Mason posted Thu, 22 August 2002 at 12:30 PM
How about an uber material setting app. Something that allows more control over the material settings than poser does. For example, if I want to change the color of all the materials in a character I have to march through each material and do it seperately. An app that allows you to check mark which materials to change then change the color for all of them would be real cool. Maybe the materials are listed in a list control. You could multi select the materials to change then click the color button and select the color for all those materials or select the map button to set the maps for the selected items. Also, Someone's been writing me and asking for a way to copy all morph targets from one cr2 into another in one swoop. I'm real busy and don't have time to do this. A small DOS command line utility or even a drag drop utility would be ideal. The drag drop app would specify a destination cr2 then any cr2 you drag onto the surface is copied into the destination.
konan posted Thu, 22 August 2002 at 12:38 PM
Please keep the suggestions coming! The feedback is fast and furious! I love it! ------------------------------------------------- David John Fielder (Konan) Proprietor of Innuendo Software http://innuendo.ev.ca
2002LaughingVulcan posted Thu, 22 August 2002 at 12:45 PM
An extension of what TalmidBen said: Perhaps something that would look at the .obj & figure the best joint setup for the parts, with some help from the user... Basically the conforming clothes are figures themselves, so it's the same thing. Anything that helps with joint setup on custom figs would be appreciated by this weary modeller... :D
hogwarden posted Thu, 22 August 2002 at 12:51 PM
Sounds a bit like PBooost in concept? If I had a couple of other expensive apps to draw attention to, maybe I'd have made that free, too. H:)
ChromeTiger posted Thu, 22 August 2002 at 12:52 PM
I like the idea of a 'path correction' utility. Something that will read the texture reference of a .xx2 file, check the path validity, and correct the reference to whatever is exact for the user's system. Not sure how this would affect Poserr 5, but I can tell ya it'd dang sure speed up load times in Poser 4. One wrong reference and everything loads TURTLE slow...
Stormrage posted Thu, 22 August 2002 at 1:01 PM
Mine's simple.. an uninstall utility that would install, obj, textures, (main file cr2 pp2 whatever,) so that when you are cleaning out poser you don't have to figure out where to get rid of everything. As long as YOU KNOW WHAT YOU ARE DOING you'd have no problems keeping the obj's YOU do need
konan posted Thu, 22 August 2002 at 1:03 PM
Ah, now I get it. It is a speed issue. I knew that Poser would look for these files itself, so at first I failed to see the relevance. But now I know that it is about speed, it makes more sense. Hey hogwarden, It is not my wish to be redundant in any way. I am not too familiar with PBoost, so if any of these things are "already done", then please let me know. I am looking to do something original here. Is anyone interested in an animation based utility? One that will make animation easier to do? Please post your ideas. ------------------------------------------------- David John Fielder (Konan) Proprietor of Innuendo Software http://innuendo.ev.ca
jjsemp posted Thu, 22 August 2002 at 1:05 PM
How about a utility that lets you choose the main subject or subjects in a scene and then instantly sets up LIGHTS for that scene. The utility should automatically aim the lights on that subject that you've chosen. There should be various options for different kinds of lighting (i.e. daytime, night, spooky, rainy, etc.). It should make lighting a no-brainer. And, yes, I know that there are light sets available, but they aren't always aimed correctly for the way a scene has been set up or the specific subject that you want to light.
BazC posted Thu, 22 August 2002 at 1:07 PM
Well this might be a tall order, I don't know the first thing about programming. But what I'd love is a searchable database of all my Poser stuff, each file would have a card with a thumbnail of the object and fields for where you got it, who made it, what character its for, what type of file it is (prop, room, lighting, texture whatever!) and its location. Plus a description field and a comments field. Then if you're looking for an old man texture/ character for mike you just put those in the search fields and it pulls up a list and you realise what you want is on a CD you lost 6 months ago! Oh and I want it for OSX please. I suppose there are commercial packages that will do this but the only one I've found that does what I want is Portfolio and it keeps crashing! Baz
BazC posted Thu, 22 August 2002 at 1:14 PM
Oh and Stormrages uninstaller is a great idea! I have to keep my runtime pruned on my weedy 10gig hard drive :o) Baz
LordNakagawa posted Thu, 22 August 2002 at 1:31 PM
I Second Stormrage's idea a program that can uninstall a file and it associated obj's is just what I'm looking for
Bobasaur posted Thu, 22 August 2002 at 1:35 PM
I'd like something that would pull all the relevant files of a project (including textures, objs, etc) together for archiving. It would probably be similar to an uninstaller but instead of removing things it would make a complete project archive directory that could then be zipped or stuffed (I'm a Mac guy) and put on a CD. I'd ultimately love to be able to put the archive back on the computer in six months and be able to have every project file together in one place regardless of whether or not I've removed the original files/props/textures in the interim. Maybe this would be more like an uninstaller with an "Project Archive" option.
JOE LE GECKO posted Thu, 22 August 2002 at 1:38 PM
A utility that would help faking area lights. You choose the shape ( sphere, box,... ) and it would create an array of spotlights pointing outside the virtual object and which orientation would depend on the virtual object faces normals... Not sure if it's really clear :)
yggdrasil posted Thu, 22 August 2002 at 1:50 PM
I like the path correction idea (was considering biting the bullet and writing one myself). Why? Two main reasons. 1) I have pro-pack. A lot of .xx2 files have a .bum reference but the shipped texture was .jpg. Given the huge library of stuff I've built up fixing this in a text editor is a bit of a pain. 2) Mis-spellings, incorrect location references, foreign folder names all make the texture slower to find. Ideally I would see it working as follows: - Scan all .xx2 files in target folder for texture and object references. - Check specified path to see if file exists. - If not there, check for -- file of same name but different extension at specified path -- file of same name and extension in another path -- file of same name with diferent extension in another path - present results to user to allow them to make decisions on which changes to apply to the original .xx2 files This would be a great time saver, and help me tidy up my collection while waiting for P5. -- Mark
Mark
kawecki posted Thu, 22 August 2002 at 2:14 PM
I have an utility that allows you view in real time props (pp2), 3ds, obj and dxf meshes, (maybe I expand it including cinema4d and vue meshes) : PropViewer 2 in the free stuff. You can launch it as command line too, passing the mesh file name as parameter, so you can use it if you want, as part of other yours applications. Your software can open the PropViewer window by a function call: exec PropViewer.exe "c:poserMyStuffsome mesh.pp2" And for closing the windows you can call Kernel's kill task. NOTE: Only for Windows, maybe for Linux, but not for Mac.
Stupidity also evolves!
Khai-J-Bach posted Thu, 22 August 2002 at 2:18 PM
dunno if it could be done.. but I'd like to see a way of adding morphs to a figure other than click, click, find name, hope you got the right one, etc.. kinda like just drag a thumbnail of the morph onto the figure and thats it....
konan posted Thu, 22 August 2002 at 2:34 PM
Hey kawecki, I am unsure as to what you point is. Are you suggesting that I integrate the prop viewer into the utility program(s)? Hey Kaibach, Can you read the info on Poser 5 and see if it has any features like the one you suggest? If not, than a utility would definately be a good idea (especially for the growing Extreme Morph 3D community :) Konan
audity posted Thu, 22 August 2002 at 2:38 PM
Hi Konan,
Bobasaur ask for something that I really need :
A little application that would mimic POSER folders hierarchie and include in a single folder all the necessary files for a project (textures, geometries, characters, etc...). So we can save all the contents of a scene, instead of only saving paths.
This is really important for people who need to import POSER scenes in other softwares (Cinema 4D, Vue d'Esprit, Studio MAX, etc...). With all the files spread in POSER's Runtime folder, it's a nightmare to keep track of everything.
Oh, by the way, thanks for proposing this Konan.
:) Eric
kawecki posted Thu, 22 August 2002 at 2:46 PM
Konan If you find the Prop Viewer usefull for something, you can use it.
quixote posted Thu, 22 August 2002 at 2:48 PM
Konan: Please remember that P5 allows for many different Runtimes. Might complicate things for you. Yes, I agree, Thanks a mil. Q
hazard
S Mallarmé
wdupre posted Thu, 22 August 2002 at 2:52 PM
konan posted Thu, 22 August 2002 at 3:01 PM
I am getting an idea of what this thing should be. Please keep posting so I can get some input and narrow my focus. Konan
c1rcle posted Thu, 22 August 2002 at 3:07 PM
something that can read an mtl file then scan the textures folder & copy the textures named in the mtl to the folder the mtl is sitting in. Rob
hogwarden posted Thu, 22 August 2002 at 3:52 PM
Now you can scan Poser files for incorrect image file references... they show up in Blue (file exists but path is wrong), Red(can't find the file at all) and Green (all's OK). It's an easy matter to correct these wit PBooost.
As you can see... the DFE also aids creating MAT and MAP poses in a highly intuative way... in fact, everything within the material section of the file can be changed quickly and easily to make basically whatever you want in seconds.
The "actors/Props section is not yet complete (off the bottom of the form), but it will allow total control of
everything else you could wish for within the Poser 3/4 xx2 file.
I've also added a little thing to delete geometry RSR files in a single bound.
hogwarden posted Thu, 22 August 2002 at 3:56 PM
mstrong posted Thu, 22 August 2002 at 3:57 PM
How about a utility that randomizes the morphs between 0 and maybe 1.5. Could be to quickly generate different characters or at least provide a starting point. mike
hogwarden posted Thu, 22 August 2002 at 4:05 PM
Staby posted Thu, 22 August 2002 at 4:10 PM
Hi Konan, thank you in advance for whatever program you are going to develope! I too would really like a path correction tool. The first thing that I always do when I download free or purchased stuff is to open the cr2 or pp2 and change the obj path or the textures paths to keep the runtime well organized or fix error or bum references. Something that let you see the obj path and the path for every texture (transmap, bump or texture) used in the cr2 or pp2 and correct and resave it would be great for me.
konan posted Thu, 22 August 2002 at 4:18 PM
Good stuff Hoggie, I will not be strating this project until Monday, so there is a lot more time to keep the suggestions coming in. I would also like to get some more suggestions for a program that "does stuff", as opposed to "fixing stuff" as well. An uninstaller seems to be the popular choice so far. Keep'em rolling, Konan
maclean posted Thu, 22 August 2002 at 4:58 PM
Hi Konan, I'm like Staby. I change all the obj pointers and paths, so a path correction tool would be useful. BUT....my main PITA now is MAT files. A program that allows you to change the MAT paths for texs and all maps, along with the obj pointers and stuff would be great. mac
Ms_Outlaw posted Thu, 22 August 2002 at 5:01 PM
There are some great ideas here. As strange as it is to believe, not everyone will be jumping to 5. I almost gave into an impulse and preordered it, but had a problem so was able to fight the urge and didn't have to watch my visa scream. With the urge past, I've decided to wait untill I actually can afford it. I doubt I'm alone. My biggest beef with p4 is the library mess. I'd love to find things. Even with all p5's bells and whistles it was the file system I was looking forward to most. Something for 4 would get a lot of use I think. And free is a real bonus.
Spit posted Thu, 22 August 2002 at 5:07 PM
Regarding textures in Runtime/textures it is my understanding that it doesn't matter where a texture is in there, Poser will find it. It seems to load up a complete list of paths and filenames in Runtime/textures when you open Poser. I've looked at some mat files that have texture paths that even refer to a different partition than mine, and Poser doesn't bat an eyelash but loads up the texture just fine. But that only depends on the filename being correct, of course, ie. .jpg vs .bum. But as long as you have a texture with the same name as in the Poser file in Runtime/Textures Poser will find it. Dont' worry about the exact path...it seems to be ignored unless the texture isn't there at all.
breathless posted Thu, 22 August 2002 at 5:45 PM
Attached Link: http://www.db70.com/bp/
I have one word for you: interactivity. If you could create a plugin that worked like the Maya Realtime SDK I think most Posers would flock to it. With the push of a button a window would launch, allowing you to navigate around your Poser world, animate characters with keystrokes, trigger sound, animation and texture events. This could be huge! Make it even better by allowing a record feature to create an animate poser file that you could then render for fast and furious animation.hogwarden posted Thu, 22 August 2002 at 5:55 PM
Staby & Maclean... PBooost does the Textures from v1.3, and obj references are coming. Spit... Yes, Poser finds the files with incorrect paths by searching for them in the textures folders. But in the process it locks the runtime folder entirely under NTFS. Try loading a file you know has incorrect paths and then rename a folder within your libraries with explorer. Won't work!! The runtime folders are locked by windows because Poser hasn't freed them. This is caused by a simple programming error... forgetting to free the search object after use.
zukeprime posted Thu, 22 August 2002 at 6:06 PM
Personally, I've been doing quite a bit of CR2 editing. Notepad and WordPad are my programs of choice, but it's rather hard to navigate large files (Michael and Vic2 come to mind), especially if you're copying and pasting large chunks. I have both CR2Edit and CR2Builder, and I find both rather confusing: CR2Edit seems powerful but I can't get my arms around the cryptic button layout, and CR2Builder doesn't quite work right for me (plus the author is Japanese, I believe, and the documentation is hard to follow. Both are good programs I'm sure, but if we're wishing.... I'd like a CR2 edit capability along the lines of Morph Manager's GUI. I like the way everything is compiled by bodyparts, where you click the '+' sign to expand the body parts to see the inner details of the settings. It would be nice to be able to see all the sections of the CR2: for example, expand the 'BODY' section to see the FBMs. Expand the material section to see (and edit) the materials. Perhaps have a left and right side (like morph manager) where I can cut and paste cr2 information from the left to the right, etc or vice-versa. BTW, if there's already something out there along these lines (other than CR2Edit and Builder) please tell me where I can get it!!! :)
Netherworks posted Thu, 22 August 2002 at 6:16 PM
bomdropr, John Stallings has a program called "CR2 Editor" that does this. I think its in freestuff somewhere. :)
Spit posted Thu, 22 August 2002 at 6:26 PM
Hogwarden...at what point does Poser lock the folder? I thought it was when you open Poser and it creates a list of all the texture paths...not just when it gets confused. So whether there's an incorrect path or not, you can't rename/delete folders with Explorer while Poser is running. Not that I do that, mind. I do all my organizing with Poser closed. Of course, since I use NTFS, I can't use PBoost either.
geoegress posted Thu, 22 August 2002 at 6:30 PM
I could use a program that would examine a pz3 and copy every file used to a destination folder. every obj, cr2 ect .......and every texture
lmckenzie posted Thu, 22 August 2002 at 6:46 PM
bloodsong posted Thu, 22 August 2002 at 6:51 PM
heyas; brycetech was working on a program that checks and bundles a package together (obj, cr2, textures, etc). dunno what is up with him and that at this stage, though. the one thing i wanted, that i mentioned in the poser tech area, is a cr2 checker. one that will parse through a cr2 (after i have edited it) and point out any inconsistancies in it. some things (and it doesn't have to fix these, some of them can be deliberate and you want to leave them in)--- the figure res file can be found on the path specified by the cr2. the hierarchy order is the same in all the different sections (actor section, channels section, figure addchild and weld sections). perhaps even a standard hierarchy order checker (ie: the legs belong after the arms, not before them, etc etc). screwed up joint parameters, where a body part's jp's don't match up to its affectors in its parent. also, extra/missing/out of order jps. like the twist listed first instead of last, or having two twists and one joint, or three joints and no twist.... etc. extra welds, missing welds. missing addchild statements. stuff in ik chains that doesn't exist, or is out of order, etc. ik chains without link weights for each entry. materials that are in the cr2, but don't exist in the obj. (and/or vice versa.) stuff like that.
Little_Dragon posted Thu, 22 August 2002 at 7:57 PM
This is probably too simple, but whatever you create, how about an additional feature that runs through all the Poser files in your Library folders, and automatically changes the version numbers so Poser 4.03 users won't get that bloody "newer version number than expected" message. Come to think of it, that'd make a nice feature for P3dO Explorer. I'm already using it to convert PNGs to RSRs for Poser 4.03; that'd save me another step in the process.
Lemurtek posted Thu, 22 August 2002 at 7:58 PM
I'll second Blooodsong's request! Regards- Lemurtek
lesbentley posted Thu, 22 August 2002 at 8:08 PM
Kaibach's idea sounds great. I'm no programmer, but it should be a snap to turn an obj morph target into a pose file to inject the morph, user would still have to spawn a morph target to put it in, but the horse work is making the pose file in the first place.
Other ideas:
1). In Poser4 way to delete all the all the lights at once would be great. 2) This might involve a hack, but keyboard arrow key control of parameter dials, it would give much greater control than curser dragging, especially on laggy machines. 3). The Holy Grail, a way to edit all the variables in a cr2 or pp2 in Poser4 memory e.g. an extension of the current cut/paste facility that only allows the values behind parameter dials to be edited.
KattMan posted Thu, 22 August 2002 at 8:10 PM
This is for Talmidben and others with similar problems and issues for conforming clothing. Take a look at my P-Wizard here in the store. It does have a conforming wizard that will take your OBJ file and the target characters CR2 file and create a CR2 file for the new clothing so it will mostly conform to the character. If you have any other questions about it IM me direct as I don't really want to hijack this thread.
MaterialForge posted Thu, 22 August 2002 at 10:08 PM
Yes, anything that will help with animation would be great! I also like Stormrage's suggestion about pulling out related files when you uninstall... Thanks for listening! --silver
Kiera posted Thu, 22 August 2002 at 11:25 PM
I would give my left arm for a MOR pose creator that also did scale injections. ;) I love EditPad, juggling between Excel, Poser, and Editpad gets REAL damn annoying. =D
RealDeal posted Fri, 23 August 2002 at 12:52 AM
I would just settle for a copy of poserloader from wolfy that would work on my win2k system. works great on win98.
hogwarden posted Fri, 23 August 2002 at 4:03 AM
Spit... not quite! As you have NTFS, PBooost 1.3 WILL WORK FOR YOU!!!! Poser does indeed search through the files in the library folders when it starts up... but I doubt it does anything with this information. This initial file scan works properly. The folders are not locked under NTFS until Poser has to search for a texture on loading a file... Under FAT32/NT things are different... either the folders lock immediately or not at all, so FAT 32 users still need to use the NT compatibility tester for PBooost in freestuff. H:)
KattMan posted Fri, 23 August 2002 at 6:54 AM
Kiera, go to my free stuff and downnload the MATMOR wizard. Granted it needs the P-Wizard to be usefull but you can install it somewhere and open the help file if you have windows. Read through that and see if you can use it for what you want. It might give you what you are looking for. Any of you that are going to dragon con might want to find me on Saturday, I'm going to have about two dozen copies to give away for free.
crisjon1950 posted Fri, 23 August 2002 at 8:21 AM
I'd like a utility that will go over any new items in my Poser installation and convert any "jpg" bump map files to the proper bum format. You've seen those files such as skintexturebum.jpg?! Apparently I had many products which didn't have the bum files converted, and I never had a clue about the problem. That includes many DAZ products. I was only made aware of this problem when I bought the DAZ Medium-res(!?) Stephanie textures. All of a sudden Poser asked me for the bum file which didn't exist. I never had a clue as to this problem with the DAZ Mike or Vicky textures. The current method is pretty cumbersome. The user has to search the hard drive for any jpgbum.jpg files to be converted. Maybe a conversion program could be pointed at a particular new item, and automatically search and convert to bum files? Then how about a program that allows us to save our newly converted bum files with the originals perhaps? How about even repackaging them into an ".exe" or "zip" file? It is a pain in the ass to manually reinstall Poser and my stuff and repeat the bum conversion all over again.
Spit posted Fri, 23 August 2002 at 8:36 AM
Hogwarden...thanks for the info!!! Crisjon...you may not want to do that. I spent more time on my old machine deleting .bum files to save space than I did using them. If you have plenty of harddrive space it's okay. But I just had Poser convert each one when I needed it.
crisjon1950 posted Fri, 23 August 2002 at 9:15 AM
The problem is that too often you have no clue if a bum file is needed, or is not converted when you wanted. I found that out the hard way after my difficulties communicating with DAZ and others. Before I got Stephanie's textures, I had absolutely no clue that many items didn't have the bum files converted. That includes Mike and Vicky's textures.
konan posted Fri, 23 August 2002 at 9:44 AM
Hoggie, Can you explain the folder locking thing a bit more. Is the folder locked in such a way that all of the files in the subfolders are not editable? Please elaborate so I do not have to spin my wheels figuring out the same things. I will be taking a long weekend, starting this afternoon (much needed), so I will not begin any work until Monday. More suggestions please :oD ------------------------------------------------- David John Fielder (Konan) Proprietor of Innuendo Software http://innuendo.ev.ca
konan posted Fri, 23 August 2002 at 11:27 AM
crisjon1950 posted Mon, 26 August 2002 at 12:49 AM
And we have MAT Pose Edit, in Renderosity Free Stuff.
Stormrage posted Mon, 26 August 2002 at 11:11 AM
3 minutes poser has ( I THINK) a few of the programs mentioned in this thread. http://www.globetown.net/~kim99/tool/index_e.html 02e AUG 04, 2002 Poser File Editor ERC Edit pz3MATList.exe 0002 JAN 26, 2002 4.Report chanege Morph Target parameter when pz2 file applied. 5.Remove morph targets of Head changed part in pz2. 6.Remove ALL morph targets changed part in pz2. pz3MATList.exe 0001 NOV 01, 2001 1.Create List of Materials from cr2 pz2 or pz3 files. 2.Create List of Morph targets from cr2 pz2 or pz3 files . 3.Create MAT Pose File from cr2 or pp2. pz3surface.exe 0001 Aug 09, 2001 Change Material parameters in pz3 cr2 or pp2 files. pz3color.exe 0001 June 10, 2001 Change Material Colors in pz3 cr2 or pp2 files. pz3white.exe 0001 May 19, 2001 Change Material Colors White in pz3 cr2 or pp2 files. pz3grepfile013.exe 0003 May 10, 2001 Check linked files in pz3 cr2 files. Mac2PC.exe 0001 Jan 5, 2001 Convert pp2 files for Mac to PC . TMPPage.exe 0001 Developping NOW! Create HTML file. It is Empty Page for 3Minutes Poser. TMPIndex.exe 0001 Developping NOW! Create HTML file. It is index for 3Minutes Poser. ImgCatHTML.exe 0001 Dec 25, 2000 Create HTML file. It is List of jpeg, gif, png files.
konan posted Tue, 27 August 2002 at 10:32 AM
Ok, I am back from my long weeked. So what's the verdict? After seeing what other utilities are already out there, what shall we do with this project? Konan
konan posted Tue, 27 August 2002 at 7:01 PM
I could not find any existing "uninstaller" programs. If there are no major objections, than this is what I'll do. Konan
Boni posted Tue, 27 August 2002 at 9:36 PM
Konan, I'm not much of an animator, so although I think your Poser to Bryce animation utility is great ... I'd rather have a freeby that imports Poser to Bryce with all textures in tact, with transparencies set etc. I know that is one function of your utility ... but to have it separate and Just do that would be awesome. Boni
Boni
JeffH posted Wed, 28 August 2002 at 11:56 AM
As long as several programmers are watching this thread I'd thought I'd make another suggestion...
"John Stallings has a program called "CR2 Editor 1.51" that does this.."
Yes, great program, but limited and John no longer updates it.
I can't get by without this tool, but large files choke it.
What we techies need (also) is a program that edits CR2, PZ3,(all poser library files) and .OBJ files (groups and materials) using the expandable tree layout, but with no memory limitations other than the system it's running on.
Kind of CR2 Editor combined with Compose and Edit pad with a tree hierarchy layout basically.
How difficult would that be?
-Jeff
konan posted Fri, 30 August 2002 at 1:01 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=848132
The uninstaller is now available. Please see the latest post. ------------------------------------------------- David John Fielder (Konan) Proprietor of Innuendo Software
