Subject: Separating an object from a character?
klisis opened this issue on Aug 24, 2002 ยท 3 posts
klisis posted Sat, 24 August 2002 at 9:08 PM
Hello, Is there anyway to separate an object, such as hair, and save it as a different file (ex : *.obj) from a character file (*pz3)? Thanks.
geep posted Sun, 25 August 2002 at 12:46 AM
Sure! Just load the hair you want into Poser on a figure. Note: the "hair" will not load if there is no figure to which it can be attached. Then just ... [menu]"File" ---> "Export" ---> "Wavefront obj..." (or other) Make sure you UNcheck "UNIVERSE" and then check only the "hair." Now you have just the hair as a separate object. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
poserpro posted Sun, 25 August 2002 at 6:45 AM
what kind of hair, geo hair or textured hair. open the hr2 file, and select the v lines, vt lines, copy and paste to other blank file and save as OBJ. you got a obj hair.
