gsalas opened this issue on Aug 27, 2002 ยท 16 posts
gsalas posted Tue, 27 August 2002 at 12:55 AM
I know that the body is the same geomentry with a ton of new morphs, but is the head? IE, it the stephany head, a morph from the original victoria head, or is it a compleetly diferant geometry, with diferant number of verticals? Thanks -Gabe-
Kagato98 posted Tue, 27 August 2002 at 1:02 AM
From what I understand, Stephanie is Michaels mesh rearranged a whole lot. So if your asking if it's the same geometry as Victoria's head, I highly doubt it :) . I think some of the morphs that Michael uses for the head would work, but I wouldn't wanna see the results :)
gsalas posted Tue, 27 August 2002 at 1:31 AM
So than victoria say chest morphs wont work on stephany then? By the way, if you are right, then stephany is a mike transexual??? Oh my... -Gabe-
DelicateCrystalRose posted Tue, 27 August 2002 at 4:06 AM
Stephanie is made from Michaels mesh and the way I understand it the Vicky chest morphs would not work on her
kawecki posted Tue, 27 August 2002 at 4:27 AM
On the other side, maybe Stephy chest morphs would work with Mike............... !!!!!
Stupidity also evolves!
creativechaos posted Tue, 27 August 2002 at 4:54 AM
Actually, the myth remains a mystery...I've had a little bit of success using The Tailor to transfer morphs from Vicki to Stephanie...but when used to extremes the mesh becomes a bit crumpled. Most of the FBM's don't transfer right...haven't tried from Mike to Steph yet, but with a program like Tailor, it might just work shrug
Remember...getting lost is the senic route to the eventual destination. (And a lot prettier than the straight road)
shadowcat posted Tue, 27 August 2002 at 5:34 AM
JDexter posted Tue, 27 August 2002 at 7:02 AM
Actually I transferred the Boris (Available in the Marketplace here) morphs to Stephanie with no problems. It opened up a lot of options for her and I am able to get looks I was not able to get before. Stephanie does take Michael head morph very nicely. If I was at home at the moment I would attach on of the hybrid faces I have been using. JDexter
shadowcat posted Tue, 27 August 2002 at 8:46 AM
oh, didn't relize that. I knew they reworked the brow so I figured they wouldn't tranfer. Hmmmmm...... need to take a closer look into those morph then.
JDexter posted Tue, 27 August 2002 at 9:21 AM
As a matter of fact, I specifically wanted some of those morphs for the brow, and they worked beautifully. The problem I was having was my lady was looking a little cranky. I was able to reshape with those morphs, now she looks like I wanted her to look. JDexter
jelisa posted Tue, 27 August 2002 at 10:24 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=170433
I also transfered head morphs from Michael to Stephanie. I used the Orc character for Michael and transfered the morphs using Morph Manager. http://www.renderosity.com/viewed.ez?galleryid=170433 http://www.renderosity.com/viewed.ez?galleryid=170436 Got another version up at my site as well. http://www.fignations.com/jelisa/dbryce/img130.html Head morphs can be transfered from Michael to Stephanie, but not setting the dials all the way to 1 helps to soften the morphs for her. -darlisagsalas posted Tue, 27 August 2002 at 12:05 PM
Hi all, I guess this strand went a bit futher ary than I was expecting. serpentis , You refered to "using The Tailor to transfer morphs from Vicki to Stephanie" What it "the Tailor". I have not heard of it, and that may solve my question. -Gabe-
LeeEvans posted Tue, 27 August 2002 at 12:35 PM
Attached Link: http://www.daz3d.com
Gabe.. the Tailor is a morph utility for sale at DAZ3D that is supposed to be used for "copying" morphs from a figure to clothing... so that the muscle morphs in M2 can be transfered to Mike's clothing, etc.... But evidently it work for creating morphs in other figures as well.. :) -LeeRHaseltine posted Tue, 27 August 2002 at 1:02 PM
For transferring morphs you use Morph Manager (in Freestuff) to put in a copy the actual offset (delta) values - the Tailor adjusts one mesh to follow the morph of another to which it conforms (clothing), or matches (as with Steph to Vic, same basic body and joint parameters.)
Jaager posted Tue, 27 August 2002 at 2:06 PM
Using the wrong verbs can confuse what is going on. The Tailor will 'translate' morphs between different geometries - if the groups line up. It is not a cut-n-paste operation. Transferring/copying morphs only works if the groups of the two files are identical. This is cut-n-paste. In most cases copying works between Mike:Steph - not hip - but since the geometries start from different places, the differences produced by the morphs may not look good. Vic:Kids is the same situation.
gsalas posted Tue, 27 August 2002 at 6:18 PM
Thank you, that helps because I am trying to speach in english, where it is not my first language. I have dificulty with "Verbs" and "Ajitives" So you would up snsering my quirie. -Gabriel
