Kagato98 opened this issue on Aug 27, 2002 ยท 8 posts
Kagato98 posted Tue, 27 August 2002 at 1:44 PM
I've been trying for the past hour to make one of my figures poseable. So far, it's turning out great. I have a question though..I know how to hide dials by editing the Cr2. For instance, if I wanted, I could hide the xRotate dial if I didn't want them rotating it on the x Axis. However, they can still rotate it using the 'rotate' tool. Is there anyway to lock an axis for an actor forever? Much thanks to the person who helps me out :)
SAMS3D posted Tue, 27 August 2002 at 2:10 PM
Yes, you have to edit the max and min section of the xrotate dial Sharen
maclean posted Tue, 27 August 2002 at 2:13 PM
The only way I can think of to do this would be to set 'force limits' to a min and max of zero. The min value always has to be less than the max, so you may have to play around with small values to get it right. Like min=0, max=0.00001 or something. Do this. Go into the cr2 and set 'force limits to 4 (on) for the trans dial, without changing the limits. Open it in poser and double-click on the parameter dial name to open the dialog box, and get the limits right. Then just save it to the Library with those limits. This will certainly work. There may be a more elegant way if there's a cr2 lock, but off hand, I don't know of one. Also, this way, the user could always open the dialog box and impose new limits, if necessary. It's a good idea always to leave the user an option. mac
maclean posted Tue, 27 August 2002 at 2:14 PM
Hey sharen, you beat me to it by cross-posting. LOL mac
SAMS3D posted Tue, 27 August 2002 at 3:11 PM
LOL, I maybe faster on the draw, but you did have more information.....Sharen PS: mine was a little vague
Kagato98 posted Tue, 27 August 2002 at 3:55 PM
I got it. Thanks :)
PheonixRising posted Tue, 27 August 2002 at 10:10 PM
HI there, So that the dial will not rotate set the min and max to zero and lock it in forced limits this: rotateX xrot { name GetStringRes(1028,4) initValue 0 hidden 1 forceLimits 1 min 0 max 0 trackingScale 1 keys { static 0 k 0 0 } interpStyleLocked 0 } or just detete this dial completely. Regards, Anton anton@daz3d.com
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
maclean posted Wed, 28 August 2002 at 2:12 PM
Thanks Anton, I wasn't sure if you could set them both to zero. I always set 'force limits' to 4, simply because, if you set it to 1, poser then changes it to 4 anyway. But anthring other than 0 works. I wouldn't delete the dial though. Someone may want to use it. mac
