Subject: where can i find or how can I make...?
kkndmaster opened this issue on Aug 29, 2002 ยท 4 posts
kkndmaster posted Thu, 29 August 2002 at 8:32 PM
Hey uhm how can I make or where can I find an anklet or ankle bracelet for the p4 woman. It should only be simple and not joe's thing. thanks for any help
Little_Dragon posted Thu, 29 August 2002 at 8:46 PM
If you want simple, use the torus in Prop Types. Scale it down, adjust the thickness of the ring, and parent it to Posette's ankle. A silver or gold reflection map will make it look metallic, if necessary.
kkndmaster posted Thu, 29 August 2002 at 8:50 PM
Hmm how do I parent it in detail. sorry I don't know how to do this.
Little_Dragon posted Thu, 29 August 2002 at 9:51 PM
Okay, after you've resized the prop and positioned it on Posette's ankle, go to the Object menu and select "Change Parent". A dialog box will pop up which lists every element in the scene. Scroll down until you find the body part to which you want to attach the torus; for an anklet, you'd probably want to parent to the right or left shin, although one of the feet might be a possibility. Anyway, select the proper body part from that list, then click OK. The torus is now attached to the figure, and will move along when the body is posed.
