guarie opened this issue on Aug 31, 2002 ยท 25 posts
guarie posted Sat, 31 August 2002 at 9:29 AM
I've just started to notice that the default fellow that appears when you fire up Poser 4.0 has started to change his hair colour. Now I may be thick and haven't noticed that this happens all the time (I do please innocence as I am colour blind) but it seems it's getting a bit extreme lately. One time it's blue, the next brown, the next yellow, the next green etc etc etc Now my questions is: Is this default fellow trying to make a fasion statement or is there something fishy going on with the defaults? Any ideas? Guarie
melanie posted Sat, 31 August 2002 at 9:47 AM
That's weird. Mine always stayed black. I've since changed it to the stick figure, but I've never had the default guy change in any way. You might want to check your monitor settings. That shouldn't be happening unless you deliberately change his texture map. Melanie
wyrwulf posted Sat, 31 August 2002 at 10:38 AM
lesbentley posted Sat, 31 August 2002 at 11:17 AM
Hey, that's the Casual Man P2, isn't it? Mine is bald, I WANT MY MONY BACK!!! ;)
wyrwulf posted Sat, 31 August 2002 at 11:29 AM
The Default Guy is the Casual Man P2 Lo, but with Poser 2 Fig hair Male Hair 1. The Male Hair 1 loads in a different color every time, so that's where the "bug" is. I can't remember if the Default Guy is in the Poser 2 Lo library by default, or if I put him there to keep him.
wyrwulf posted Sat, 31 August 2002 at 11:34 AM
I just checked, and all the Poser 2 hair loads in with a different color every time. It must be a feature not a bug.
lesbentley posted Sat, 31 August 2002 at 11:37 AM
lesbentley posted Sat, 31 August 2002 at 12:01 PM
Seriously, I have just tried loading the Male Hair 1 several times and it always comes in the same colour for me. Do you guys have the 4.0.3 patch? By the way this is the first time I have loaded the Casual Man P2 since the first day I got Pose4.
Jaager posted Sat, 31 August 2002 at 1:28 PM
Not meaning to pee in the pool, but have you considered doing this: just after you open Poser, delete the Poser 2 guy, go up to: Edit/General preferences and set this as your preferred state and tell Poser to open with your preferred state. And to open to previous state. Not having any figure - Poser opens faster and you do not have to delete the default guy every time. If you always use the same figure, you can set it to open with that one already there. You can change lights, camera focal lengths, the way a render is saved - new window etc. shadow values . Then save as preferred state. The color thing - I think if a geometry does not have a defined color or texture in the cr2, Poser will assign a random color to it. If a cr2 in the library has no materials blocks then when it opens - it does this when it writes them.
wyrwulf posted Sat, 31 August 2002 at 2:32 PM
I just figured it out. The Hr2 files for the Poser 2 hair don't reference the material in the OBJ, as Jaager mentioned, so it loads with a random color assigned. I set up my prefered state a long time ago, and assigned it to a UI dot, just for safety's sake. lesbentley, which Male Hair 1 are you loading? The one in the Hair Types folder, or the Poser 2 Fig Hair folder. The hair I'm refering to is in the Poser 2 Fig Hair folder. The Male Hair 1 in the Hair Types folder loads fine for me.
melanie posted Sat, 31 August 2002 at 6:41 PM
Gee, I feel so deprived. Mine never did that. His hair always came in black. I never get any excitement! Melanie
lesbentley posted Sat, 31 August 2002 at 9:54 PM
Wyrwulf, I'm loading from "Poser 2 Fig Hair", it always comes in at the same colour R=46, G=16, B=0. Jagger the "Male Hair 1.hr2" has the color defined, though I am not sure what the "presetMaterial Preview" is. material Preview { KdColor 0.180392 0.0627451 0 1 KaColor 0 0 0 1 KsColor 0.0392157 0.0313726 0 1 TextureColor 1 1 1 1 NsExponent 10 bumpStrength 1 ksIgnoreTexture 0 } presetMaterial Preview { KdColor 0.180392 0.0627451 0 1 KaColor 0 0 0 1 KsColor 0.0392157 0.0313726 0 1 TextureColor 1 1 1 1 NsExponent 10 bumpStrength 1 ksIgnoreTexture 0 }
whbos posted Sat, 31 August 2002 at 10:05 PM
I always have it open with nothing because it is faster. One other thing I also do is prior to setting this as my preference, I delete all animation frames and leave it at "1." This is helpful when saving poses as it doesn't prompt you to include the empty frames.
Poser 2, 3, 4, 5, 6, 7, 8, 9, 10, Pro 2014, 11, 11 Pro
wyrwulf posted Sat, 31 August 2002 at 10:15 PM
If you look at the P2 Male Hair 1 in the materials editor, the material that changes colors is Default. If you look at the Hr2 in a text editor, it doesn't reference Default as a material. I have made so many changes to my Poser installation that I don't have a clue if it ever worked properly. I may just load Poser into a new folder to see what the original installation looks like.
Jaager posted Sat, 31 August 2002 at 10:48 PM
presetMaterial Preview is something from Poser 3. It duplicated every material block with the second as presetMaterial XXXXX. At least I seem to remember it that way. Poser 4 only does material, so if the other is in there, it is legacy from Poser 3. Cut it out, save, open and save from Poser 4, does not come back.
lesbentley posted Mon, 02 September 2002 at 11:25 AM
Wyrwulf, my Male Hair 1.hr2 does not have a material called "Default" in thew materials editor, only one called "Preview"
wyrwulf posted Mon, 02 September 2002 at 11:57 AM
I'm running Poser version 4.03.126 as shown in the HelpAbout Poser splash screen. My original Poser 4 is the first sold by MetaCreations. I wonder why the difference?
lesbentley posted Thu, 05 September 2002 at 1:07 AM
What you mean the VERY first copy!?! I'm on a PC, are you on a PC or a mac? That could make a diffrence.
wyrwulf posted Thu, 05 September 2002 at 8:18 PM
I'm on PC. Not the VERY first copy, but I preordered Poser 4. I probably preordered Poser 3, too. I bought Poser 2 from Computer City about a year before Poser 3 came out.
lesbentley posted Sat, 07 September 2002 at 11:59 AM
Well wyrwulf, perhaps they shipped two versions of the P2 Male Hair 1, I am pretty sure mine is in the original condition I got it in, because after the first day I banished the default figure and loaded to a blank document, just lights cameras and the ground plain. I never touched the default figure or his hair again until I read this thread, but it's not just you, other people are experiencing this, so it's no freak accident. I guess we may just have to put it down to another great unsolved mystery of the Poser universe.
wyrwulf posted Sat, 07 September 2002 at 1:31 PM
I just did a fresh install of Poser 4 and looked at the Poser 2 hair. The only material in any of the Poser 2 hair is Preview. I then downloaded the update from CL and ran it on the new install. The hair stayed the same. Somewhere, there must be a download that has installed new Poser 2 hair OBJ files. It might have been one of the unofficial Poser 4 updates. I was thinking that it might be a Zygote/DAZ freebie that makes the P4 hair work on the Mill people, but I couldn't find any other hair that references the P2 hair OBJs.
lesbentley posted Mon, 09 September 2002 at 9:30 PM
I would have thought the problem was more likely to be in the hr2 than the object.
lesbentley posted Mon, 09 September 2002 at 9:34 PM
Perhaps I'm wrong there, what if the UV coordinates were missing would that cause it? Perhaps its just a corrupt rsr?
wyrwulf posted Mon, 09 September 2002 at 9:45 PM
I deleted the geometry RSR, and it didn't make any difference. I opened the OBJs for the P2 hair with a text editor and there is a line for a material called default. I deleted that line in all the P2 hair OBJs and they load fine now. I will have to reload P4 again to look at the original OBJs. There are notes in the files that are commented out with a #. Some of the notes have dates and names in them.
wyrwulf posted Mon, 09 September 2002 at 9:47 PM
I also looked at the OBJs with UVMapper, and they are OK from that standpoint.
