Forum: Poser Technical
Subject: Technical question!
Metrini opened this issue on Aug 31, 2002 ยท 6 posts
Metrini posted Sat, 31 August 2002 at 5:21 PM
Does anyone know if there is a limit as to how many folders I can have in the POSE option for example. Is it 250 or 255?? I was doing an experiment and realised I couldnt read the folders after 256 Any ideas?
lesbentley posted Sat, 31 August 2002 at 8:29 PM
I quote Hogwarden: "You will start to run into problems when you get to having more than 256 subfolders in any library folder... Then Poser will start to truncate the names, or load the files incorrectly."
Metrini posted Sun, 01 September 2002 at 6:39 AM
is there a solution to that problem??
lesbentley posted Sun, 01 September 2002 at 6:16 PM
Hogwarden has a utility called "PBoost" That addresses that problem, I think it's available here in the store. I don't have it myself, but the comments I have heard are generally quite favourable.
lesbentley posted Sun, 01 September 2002 at 6:27 PM
Sorry that should have read "PBooost" (with 3 o's).
Metrini posted Mon, 02 September 2002 at 11:53 AM
woot thanks!
