Red_Baron opened this issue on Aug 31, 2002 ยท 6 posts
Red_Baron posted Sat, 31 August 2002 at 6:00 PM
for cel style renders in poser, posette and vicky's eyes are problematic. Is there a morph for that removes eyelashes? also, there was a morph by mazak to get rid of the transparent layer around the vicky's eyeballs but its not available. can anyone tell me how to do this?
Little_Dragon posted Sat, 31 August 2002 at 6:29 PM
You'd have to contact Mazak about his morphs. They're posted on his website, but the download link doesn't seem to be working.
You can find "no-eyelash" morphs for Victoria and Stephanie in Free Stuff. FishNose and OpticalSingenoid collaborated to create real eyelash props for those characters (they look great in Cartoon mode), and morphs to hide the original lashes are part of the package.
As for Posette's lashes, I might be able to come up with something. Give me a few minutes to try.
Red_Baron posted Sat, 31 August 2002 at 7:21 PM
you are the cel render guru!
Little_Dragon posted Sat, 31 August 2002 at 7:33 PM
Red_Baron posted Sun, 01 September 2002 at 8:28 PM
the nolash morph works perfect, the only problem is those fishnose lashes show up as blocks instead of individual lashes in cartoon mode.
Little_Dragon posted Mon, 02 September 2002 at 1:31 AM
As for the RealLashes, the individual lash follicles are very fine and tightly packed.
In Cartoon w/Line display style, Poser will draw a black line around each lash follicle, so it still looks solid unless you are rendering at high resolution and/or zooming in very close.
I'd recommend that you change the lashes' default style to Cartoon, rather than Cartoon w/Lines. Then the lashes won't have outlines, and will have better definition.
To do this, select the lashes, then ...
Display menu --> Figure Style --> Cartoon
If you do so, you'll get results like above.
Note that by using this method, you can mix-and-match display styles for different figures in the same scene, or even individual elements. For instance, you could have a cartoon-shaded character wearing a texture-shaded shirt, with wireframe eyes and pants.
