Vaddix opened this issue on Aug 31, 2002 ยท 9 posts
Vaddix posted Sat, 31 August 2002 at 9:55 PM
retrocity posted Sat, 31 August 2002 at 10:26 PM
Banding often happens like that if you are working in INDEX mode or setting your resolution to 72DPI with a limited color palette. Are you working in RGB? Are you using WEB SAFE colors? What is the resolution and the image size? Save the brick! We'll help you! :) retrocity
Vaddix posted Sat, 31 August 2002 at 11:29 PM
The image is 2000 by 2500 pixels. The Resolution is 200 dpi. It is in RGB mode. I can't understand why this is happening.....reaches for the brick
Vaddix posted Sat, 31 August 2002 at 11:31 PM
PS - if it makes any difference I'm using colors from the Pantone Coated Pallette....
retrocity posted Sun, 01 September 2002 at 12:53 AM
Yikes! That's very odd (or my brain isn't working...) What method are you using to create the "rays"?
Heronheart posted Sun, 01 September 2002 at 12:56 AM
It looks like you've got a gradient in this image. It's not uncommon to get banding in a large gradient. Use the noise filter on it. If you set it right, you can get rid of the banding without introducing any visible noise. - Ken Heronheart -
Vaddix posted Sun, 01 September 2002 at 3:46 AM
Thanks Heron - I'll give it a try. But no there is no gradient. Retrocity - I was creating the light ray effect using the airbrush on a new layer. I've since tried doing it on a solid color layer with much better results. However if I adjust the levels even slightly the bands will show, such as above. But even though I was creating them on a new layer, surely Photoshop is a powerful enough tool to be able to handle the transperancy. Could low computer memory be at fault?
Vaddix posted Sun, 01 September 2002 at 5:04 AM
Valandar posted Wed, 04 September 2002 at 3:16 PM
Try adding about 15%-20% Gaussian Monochromatic noise, and then a Gaussian Blur with a pixel radius equal to about 5%-10% of the shorter image dimension.
Remember, kids! Napalm is Nature's Toothpaste!
