Subject: poser to bryce i/o bad media error
Tirjasdyn opened this issue on Sep 01, 2002 ยท 8 posts
Tirjasdyn posted Sun, 01 September 2002 at 12:39 PM
I like to render in bryce and usually I don't have a problem. But some models, when I convert them to obj's in poser won't import into bryce. they give the i/o bad media error. So far I've had this problem with sekmet's amaphoras, the greek clothing just released at DAZ and some pitch fork in renderosity. Can anyone help me with this?
Tirjasdyn
http://michellejnorton.com
Kiera posted Sun, 01 September 2002 at 12:45 PM
Yes. Open the exported OBJ in UVMapper. (www.uvmapper.com) Resave the OBJ. Open in Bryce. The problem is.. you lose all your textue settings and have to redo them. =/ But it's the only way I know that fixes it.
jelisa posted Sun, 01 September 2002 at 1:23 PM
If you are using Pro Pack, open the exported obj in WordPad, search for #IND. If found, replace all occurences with 0 (zero). When done, save the obj file (as a new name if you wish), then import into Bryce. -darlisa
pokeydots posted Sun, 01 September 2002 at 7:33 PM
I got the same error so I exported the dragon as a 3ds file and applied the textures in bryce, and it worked fine that way :)
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
2.80GHz, 4000MHz System Bus, 2MB L2 Cache + 6MB Shared L3 Cache
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphics
System Ram:  8GB
Tirjasdyn posted Sun, 01 September 2002 at 11:43 PM
Thanks for the suggestions! I'll try them out. I don't mind losing the texture settings...I usually have to adjust them all anyway.
Tirjasdyn
Bladesmith posted Mon, 02 September 2002 at 1:32 AM
And thank you Jelisa....I've had propack only a few weeks and Bryce hates it's exports...thankyouthankyou!
Spit posted Mon, 02 September 2002 at 4:18 AM
Hope this Propack export bug didn't make it into P5 :(
jelisa posted Mon, 02 September 2002 at 2:31 PM
Attached Link: Pro Pack Fixes
You're welcome, Bladesmith. The link above is a page I created of a few Pro Pack fixes. Just in case someone else ever needs to know how to fix this, they can be pointed there if needed. -darlisa
