Subject: Conforming Clothing Help
schoepfergeist opened this issue on Sep 01, 2002 ยท 4 posts
schoepfergeist posted Sun, 01 September 2002 at 4:38 PM
I'm a Poser newbie so forgive my ignorance, but i'm still having problems getting clothing to fit properly. I've poured over the manual and tons of tutorials but i'm still not getting it.
Stupid Example: I create a new Victoria figure, adjust the shape (say...larger breasts...) then I want to apply clothing.
I've done the Conform To command and then the parameter dials help some, but obviously they still don't quite do the trick. My question is...what do I turn to next?
Morphs? Magnets? The grouping tool?
I've been browsing through the galleries and i'm amazed.... How do you guys get your clothing to fit so perfectly? Are you all using "Taylor"? I'm on a Mac so I don't have that luxury.
Any suggestions or tutorials would be appreciated.
Cheers,
-Schoepfergeist
guarie posted Sun, 01 September 2002 at 7:04 PM
I must admit I have had this problm as well - one of the best things I find is if it doesn't fit correctly (apart from deleting the item in frustration and trying something else) is to make whatever the offending body part invisible (if you can). I know it's not the best solution and won't work everytime but it does work pretty well in a lot of situations.
KattMan posted Sun, 01 September 2002 at 10:24 PM
ok for the solution here without the Tailor you will need to master magnets. Essentially create a magnet over the breast of the shirt and pull it out so that it comes close to match the breasts you want without allowing them to peek through. Hiding the chest can so,etimes help, but if you need to show even part of that area you won't be able to hide it. This just means more work with the magnets. The good part about this is that you can then export that new shape for the shirt chest as a morph target and easily load it up again nect time you need it.
schoepfergeist posted Mon, 02 September 2002 at 1:26 AM
Thanks Kattman, I figured that was probably the case. I started experimenting with the magnets but I can tell it's going to take a little practice.
