PoisenedLily opened this issue on Sep 05, 2002 ยท 9 posts
PoisenedLily posted Thu, 05 September 2002 at 12:52 AM
I am trying to scan in a magazine image I found to use in a texture but I keep getting funky lines in it no matter the dpi I use. I am not a big scanner person so does anyone know why this happens? Thanks for anyand all help :)
TrekkieGrrrl posted Thu, 05 September 2002 at 1:02 AM
Depending on the scanner and scanner software there might be an option to turn them off. I'm not sure (as my scanner can't do it) but try looking for something like scanlines or moire. If the scanner/software hasn't got that option, try rotating the magazine just a few degrees, that might also do the trick, it's due to the fact that magazines usually are rasterized and that can indeed create funky lines in a scan. Hope it helps :o)
PoisenedLily posted Thu, 05 September 2002 at 1:49 AM
Thank you so much I will try that :)
guarie posted Thu, 05 September 2002 at 1:51 AM
As a print designer who uses a scanner all the time - I think I know what you're problem is. Stuff that is printed in magazines (or anywhere for that matter) are printed with a screen. When a scanner scans something it scans with a screen. The 2 screens together create the moire pattern you're seeing. To get around it you need to use a 'descreen' (there should be a couple of options depending on your scanning software - 72/85, 133, 150 etc - try 133lpi). This should help. If you still get a slight pattern and are using Photoshop, then use the despeckle filter. This should help. Any more questions just ask. Guarie
TrekkieGrrrl posted Thu, 05 September 2002 at 3:00 AM
Oh yes, descreen, that's the word G Anyway not all scanners has a descreen option, none of the 3 I've had so far has the option and one of them is a fairly high end scanner :o) So if there's no descreen option, a slight rotation usually helps, possibly followed by some Photoshop postwork.
PoisenedLily posted Thu, 05 September 2002 at 3:37 AM
I will try all of these wonderful suggetions...just not tonight. lol Its 4:30 am and in order to use my scanner I have to drag my tower out unplug my tablet plug in the scanner then re plug and AHHH! lol The perils of running outta USB ports. But thank you all. So much help...I love it here :)
shadowcat posted Thu, 05 September 2002 at 3:50 AM
descreening & blurring can help a little. another option is to scan a larger image then you intend to use, then once it's scanned reduce the resolution a bit.
spectre3 posted Thu, 05 September 2002 at 5:34 AM
Might I suggest you get a USB Hub? I have one which plugs into a single USB port, and is capable of supporting up to 6 USB devices. They are really quite inexpensive. It would save you the pain of swapping out USB devices :)
PoisenedLily posted Thu, 05 September 2002 at 11:57 AM
Thanks again for all this help :) And Apctre 3 I am going to RadioShack TODAY to get that. I was leery of doing it before because I didnt know the name and frankly, they look at you funny when you say "ya know that thingamajig" lol. Thanks everyone.
