shadowcat opened this issue on Sep 06, 2002 ยท 14 posts
shadowcat posted Fri, 06 September 2002 at 4:32 PM
shadowcat posted Fri, 06 September 2002 at 4:37 PM
Aureeanna posted Fri, 06 September 2002 at 5:11 PM
OUTSTANDING!!!! drooling
Kalypso posted Fri, 06 September 2002 at 5:24 PM Site Admin
These look great! Thanks, would the same settings then apply to all clothing items? I'm thinking of the Medieval dress at Poser Style.
shadowcat posted Fri, 06 September 2002 at 5:34 PM
No, the preteen girl's arms are bent forward a little & the belly sticks out. Making the clothes fit requires changes to the base .obj thinking about making a tutorial for doing it, but here's the quick run down. import the .obj into poser, all boxes unchecked except "weld identical vertices" scale the object to 75% & line up to the preteen in zero position (turn off inverse kin., set the y trans of the body & the hip to zero & zero the pose with joint editor) once the .obj is position to the preteen you then need to use magnets where skin pokes through (tummy & arms) save the .obj (boxes 1, 3 & 4 checked) & edit a .cr2 to point to it.
shadowcat posted Fri, 06 September 2002 at 5:57 PM
oops - scale the .obj to 79% not 75%
geep posted Fri, 06 September 2002 at 6:18 PM
Very nice work! ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Roy G posted Sat, 07 September 2002 at 12:09 AM
Thanks for those usefull tips Shadowcat! I want to try this.
pendarian posted Sat, 07 September 2002 at 12:19 AM
Darling outfits!! What clothing do you need to have in order to use them? Pendy
Dreamspinner posted Sat, 07 September 2002 at 1:04 AM
Would certainly like to see that tutorial if you have time to write it. Liz Pope Dreamspinner
lemur01 posted Sat, 07 September 2002 at 2:15 AM
Way cool, just the sort of thing I've been looking for. Jack
d_authority posted Sat, 07 September 2002 at 7:26 AM
yeah i want that one. but then again, i can't seem to get a subscription to poserstyle. :(
queri posted Sat, 07 September 2002 at 2:58 PM
Fantastic and absolutely needed by me. I just happened to need some fantasy garb for the pre-teen boy. I am hoping it works on the boy??? The top one should work well, actually. Fortunately I do have the items from PoserStyle, although I'm having some probs at their site right now. Maybe my membership has expired, but I though it was good till Oct. Emily
shadowcat posted Sat, 07 September 2002 at 10:32 PM
Well, I sent it and it apparentlly has joint problems with the thighs on the mike tunic. The pant & vicky tunic has no problems. Once it gets fixed it will be in the members area so there will be no messing around with mover! Unfortunatlly those 2 joints are giving me trouble. I might just make the "skirt" portion a solid part of the hip and make morphs for leg movement. (if I can't get it fixed soon, grrrr...) PS - for those peole whose subs have expired, don't panic, arrangements will be made. But go see the previews of coming releases, there are some great items slated.
