rob_hart opened this issue on Sep 08, 2002 ยท 3 posts
rob_hart posted Sun, 08 September 2002 at 10:41 PM
Has anyone else had this happen? Poser 4 (Mac) freezes after I make movie. It will make the movie and the new quicktime file will appear but I can't close it without freezing my whole computer. I'm on a Powerbook 400MHz, 512 RAM. Thanks, Rob
TalleyJC posted Sun, 08 September 2002 at 10:47 PM
It happens to me once in a while... I am in the habbit of saving before rendering.... I think it come down to a file sharing problem.... some how related to number of frames and frame rates. I think that depending upon the number of frames and how your machine might be buffering or cache writing, the file is not closed when the player tries to open it.
gryffnn posted Mon, 09 September 2002 at 6:20 AM
I almost always render movies as a series of images. If there's a problem, you can just begin again at that point, instead of starting over. Also can archive the images and go back and use them for another format, size, compression level, or other uses. If you've got QuickTimePro (a good deal at $29) you can assemble the sequence of stills into a movie in a snap. HTH - Elisa/gryffnn
