stephendaedalusx opened this issue on Sep 10, 2002 ยท 11 posts
stephendaedalusx posted Tue, 10 September 2002 at 10:37 PM
For the past couple of days, I have been able to view thumbnails, but full images won't load. Is this a problem that others are experiencing?
lelionx posted Wed, 11 September 2002 at 2:16 AM
i'm having the same problem.
kbennett posted Wed, 11 September 2002 at 11:03 AM
This is usually down to messed up cookie. If you choose the 'Leave' link in the sidebar, and then close ALL browser windows, then come back to the site and log in again it should rewrite a new cookie and allow images to be viewed again. OTOH it could be down to the server work that's currently going on, but try the 'Leave' link first. Kevin
LaZenMonk posted Sat, 14 September 2002 at 5:07 AM
No image file will load, not even the banner ads on top :-( Have trashed all cookies and still will not load. Let's hope it the server modifications. Mac OS 922 IE 515
LaZenMonk posted Sat, 14 September 2002 at 5:15 AM
Almost forgot works fine in: Mac OSX 10.2 using IE
lelionx posted Sat, 14 September 2002 at 9:21 AM
i'm using aol 7 with ie 5.5 anyone else.i'm wondering if this is an aol problem.anyone else using this?
bevchiron posted Sat, 14 September 2002 at 12:01 PM
Have you checked that you are actually logged in? If you can't log in check your computers clock, if that isn't set right it effects the login process (don't ask me how!!). Some of the banner ads are missing because of the server change but you should be able to view images.
"You need chaos in your soul to give birth to a dancing star...." (Nietzsche)
LaZenMonk posted Sun, 15 September 2002 at 1:46 AM
I assure all that I've tried all the obvious things and still can't load any pict files... All input stops. Browser shows links. i.e. "http://www.renderosity.com/photos/Graphic372.jpg"
fur posted Sun, 15 September 2002 at 1:01 PM
Cookies are saved based upon your local computer's clock. Another thing to check is to make sure your clock is set to the proper day, time, and year.
LaZenMonk posted Sun, 15 September 2002 at 4:25 PM
This is weird & frustrating.
lelionx posted Sun, 15 September 2002 at 11:14 PM
resetting the clock worked for me.it was set to 2008. thanks, leo
