egaeus opened this issue on Sep 11, 2002 ยท 8 posts
egaeus posted Wed, 11 September 2002 at 12:31 PM
My last message was inundated under piles of Poser 5 queries, so I'll try again. I'm using the boots available at Animotions for Vicky, but the figures are locked and can't be unlocked by conventional means (i.e. pressing the Lock Actor choice to uncheck it -- it won't uncheck). I tried setting the parent to the Universe, but that didn't work, and the Change parent option is unavailable. Any other suggestions? Mike
VirtualSite posted Wed, 11 September 2002 at 12:41 PM
I don't know the files, so this is a guess. Are you sure they're props and not conforming clothing? That might explain the unavailablility of Change Parent. You could also look at Point At and see where that's going.
egaeus posted Wed, 11 September 2002 at 12:57 PM
They're conforming clothing figures. I didn't see a Point At dial. I'll have to look again. Mike
wdupre posted Wed, 11 September 2002 at 1:25 PM
wdupre posted Wed, 11 September 2002 at 1:27 PM
egaeus posted Wed, 11 September 2002 at 1:44 PM
Yes, but choosing "Point At" creates a dial in the object's parameters that is labeled "Point At." If there is no "Point At" dial, than the problem is not the Point At command. I suspect there's something in the .cr2 but don't know enough about changing such things. Mike
black-canary posted Wed, 11 September 2002 at 2:57 PM
there's a "lock figure" option on one of the menus that's separate from the lock actor option.
egaeus posted Wed, 11 September 2002 at 4:34 PM
That did the trick. Thanks! I don't know how I missed that. Mike
